'11 T-case ground mod to trick Rubicon it's in 4Lo for lockers and traction control
I've been looking a lot for this mod and I cannot come up with anything positive. I want to ground my transfer case so that I can trick my jeep that it is in 4 low. I want to be in 4 hi or 2wd while I lock in my axles or so that I can fully turn off traction control. There is a wire that is to be grounded but I do not know which wire/colors or where it is located. I've also read somewhere that you can put a resistor in line....? I would like to put a switch on it so that I can only use this mod when I really want to.
I know that by doing this mod, the 4x4LOW is displayed all the time.
If you have any info or pictures that would be great!!
