1310 Coast DS
How can you tell if your drive shaft is vibrating? I tore my boot on my front drive shaft so I switched to a Coast 1310 but something doesn't feel right or I am just paranoid! Would you feel it in the steering wheel or would the T case level be shaking? None of which is happening but just do not want to find out the hard way.
Pull the driveshaft and go for a drive. If the vibes go away, you just narrowed it down.
If that was the problem, re-install the shaft and start messing with your control arms.
