14 bolt vs sterling 10.5 vs dana 80 (rear)
Old Jul 4, 2014 | 02:15 PM
GreatWhite JK's Avatar
Default 14 bolt vs sterling 10.5 vs dana 80 (rear)
I know the 80 is stronger than both the 14 bolt and sterling 10.5... but I am trying to decided between the 3. I know the 14 bolt and the sterling 10.5 would be more practical with my 3.6 V6. I would like to see your junk yard axle swaps and your thoughts on your set up.
Old Jul 4, 2014 | 03:02 PM
5150cliff's Avatar
Wow, what kind of wheeling do you do to need an 80? I do a lot on my 44 and 30 on 37's. Just can't imagine the need for an 80!
Old Jul 4, 2014 | 03:43 PM
Its a piece of mind that you did all you could to prevent breaking.
Old Jul 4, 2014 | 04:21 PM
Maertz's Avatar
id go 14 bolt rear and shave it. There pretty common and decent aftermarket. id say 14bs are slightly stronger than a sterling. For the front personally id go a ford 60 front. depending on tire size im sure you will want 5.38s. Id look at how you want to build them and see whats available im sure the d60 and 14b have more locker options, but that depends on what you want to run.. My ford 60 front i had to cut some housing, but if i recall a sterling front you have to cut a ton. I think 2climbig and abendx are running sterlings...Either way id try and get as wide as you can to help outboard...
Also i believe a 10.5 is metric lugs, the 14b has pinion support and drop out 3rd member...
Old Jul 5, 2014 | 03:17 PM
Originally Posted by Maertz
id go 14 bolt rear and shave it. There pretty common and decent aftermarket. id say 14bs are slightly stronger than a sterling. For the front personally id go a ford 60 front. depending on tire size im sure you will want 5.38s. Id look at how you want to build them and see whats available im sure the d60 and 14b have more locker options, but that depends on what you want to run.. My ford 60 front i had to cut some housing, but if i recall a sterling front you have to cut a ton. I think 2climbig and abendx are running sterlings...Either way id try and get as wide as you can to help outboard... Also i believe a 10.5 is metric lugs, the 14b has pinion support and drop out 3rd member...
I am leaning toward the 14 bolt but i want a Detroit locker i don't think they make one for 4.56 and up...
Old Jul 5, 2014 | 03:21 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Need to keep this thread in my participated so I can reference
Old Jul 5, 2014 | 03:22 PM
Maertz's Avatar
Detroit GM 10.5 14 Bolt Locker - Detroit Locker 225S10
Old Jul 5, 2014 | 03:55 PM
haha I'm going to honest i didn't she were it said "fits all" when i was doing research on my phone. Sorry I'm still trying to figure out this iPhone. I just assumed it meant 4.10 and below.
