15" or 17"???
Old Apr 11, 2011 | 05:54 PM
dieselskid's Avatar
Default 15" or 17"???
So I have decided to get some new tires for the JK... I have decided on the Crager steelies of course
now the big question.. should I go with a 15" rim or 17" ...... I have always had good luck with the mickey thompson MTZ's so that the rubber I will be going with (35's) ..
Other then looks can anyone tell me the advantage or disadvantage of both sizes??
thanks dudes!
Old Apr 11, 2011 | 05:58 PM
Scott-BC's Avatar
Appropriately backspaced 15" rim saves you big $$ on tires, and increases tire flex for when you're crawling. Disadvantages? Probably less stable on the highway.
Old Apr 11, 2011 | 07:49 PM
08JKRHD's Avatar
why no 16's?
Old Apr 11, 2011 | 07:55 PM
KyleTheGrouch's Avatar
I got 15s with my 35s for more rubber. And more airdown power.
Old Apr 11, 2011 | 08:14 PM
Dante's Avatar
I'm going to get the Black Rock Type D 909b 15x8 wheels in matte black with 35x12.50R15 KM2s when my current tries wear out. I only have have about 5K to go so I may order soon.
I'll be ordering from Discount Tire Direct. They had the best prices.
Old Apr 12, 2011 | 03:54 AM
CJ7nvrstk's Avatar
Vet Army
Love my 15's.
Only disadvantage I see with the 15" wheels is that you are limited in choice if you want to go to a tire larger than a 35.
Since mine is a lifted Jeep on 37's, I really doubt there is any significant difference in on road stability/cornering as compared to a similarly clad Jeep with a 17" wheel. Keeping in mind too that it is a Jeep and not a Ferarri.
Old Apr 12, 2011 | 03:59 AM
Tavic's Avatar
Originally Posted by 08JKRHD
why no 16's?
There's a larger selection to choose from. A majority of vehicles on the road today run 15's or 17's from the factory.
Old Apr 12, 2011 | 05:10 PM
dieselskid's Avatar
Thanks for all the input guys! ... Now the next question...
17x8 OR 17x9 ???
I will be running Mickey Thompson Baja MTZ Radial Traditional Light Truck Tire..
Size: 17" X 34.6 " LT315/70R17 11.90 (Width)
What are your thoughts on rim size?? Advantages/Disadvantages
Thanks again!
Old Apr 12, 2011 | 05:14 PM
GreenJK07's Avatar
I would say 17's. 17x9 Way more options than 15's.
Old Apr 12, 2011 | 06:03 PM
Scott-BC's Avatar
17x8 OR 17x9 ???
Thanks again!
Not a lot of difference between the 2...17x8 will allow you to air down a bit less than the 17x9, less chance of blowing a bead during sidewall flexing. 17x9 will allow for wider tires...other than that I can't see there being a lot of difference.
