15 Inch Wheels
Yeah I said screw it and went with 16's. I figured it wasnt worth the headache of worrying about buying 15's then them not fitting and being out of luck, i know 16's will fit. Just my two cents.
Some one posted earlier that it is a "wheel to wheel thing".
Anyone that HAS had problems fitting 15" wheels, please post wheel make, model, dimensions and back spacing.
Anyone that HAS NOT had problems fitting 15" wheels, please do the same.
Maybe we can get a concensus on what brand and model wheels do and do not fit over the calipers(especially front ones)
15X10 cragar soft 8's
backspace is 4 inches
offset is -38.00mm
these did not clear at all. i even tried an angle grinder and still couldn't get clearance. had to use spacers to get clearance. they fit just fine on the back though.
Wheel backspacing has NOTHING to do with whether or not the wheel will hit the caliper. That is dependant on how the wheel center is made. Backspacing only determines "where" the wheel will sit in the wheelwell. How far inside or outside.
