15" method double standard pics on a jk
Old May 27, 2013 | 07:30 AM
SPCmario's Avatar
Default 15" method double standard pics on a jk
Was wondering if anyone has mounted the 15" method race wheels, double standard on a jk. All the picture I've found seem to the 17" or larger
Old May 27, 2013 | 07:33 AM
951JEEP's Avatar
What's the backspace? Im running 15s (not the 15s your looking at). Mine are 15x10 with a 4.0" backspace. I have no issues.
Old May 27, 2013 | 09:12 AM
iiM RuSHiN's Avatar
Did you have to cut you calipers to run a 15'' wheel?
Old May 27, 2013 | 09:17 AM
951JEEP's Avatar
Nope, I clear em just fine.
Old May 27, 2013 | 09:42 AM
kh202's Avatar
With 15's, it all depends on the wheel on whether they'll fit or not. Find out the backspacing on them
Old May 27, 2013 | 11:34 AM
SPCmario's Avatar
It's a 3.5 in back space but I haven't seen people running them in a 15
Old May 27, 2013 | 12:28 PM
951JEEP's Avatar
That's probably why...at minimum, you need 4" backspace. You may get by if you shave the calipers.
Old May 27, 2013 | 01:07 PM
kh202's Avatar
That doesn't make any sense. 3.5" sticks out farther than 4". I would call the company and ask if they fit on a jk
Old May 27, 2013 | 01:34 PM
terrabit's Avatar
The lower the backspacing, the closer the inner mounting surface of the wheel is to the backside of the rim. That's why a wheel with a lower backspace will protrude further out of the wheel well, and why they allow more room for things like brake calipers.
Old May 27, 2013 | 02:04 PM
951JEEP's Avatar
Sorry, I was thinking it was the other way around. Thanks for clarifying
