15" Wheels a good idea?
Old Sep 28, 2010 | 01:22 PM
Jvic's Avatar
Default 15" Wheels a good idea?
I want to put 35" tires on my rubi, but 15" tires are so much cheaper than 17" tires?
First off, will 15" wheels work on a 07 rubi?
Second, any pros and cons with going to a 15" over the 17"?
Third, how much back spacing is needed for say a 35x12.50 tire (MTR or KM2)?
Thanks!
Old Sep 28, 2010 | 01:32 PM
STUPIDFACE's Avatar
In short, NO, its not a good idea. The people that post next will explain why.
corey d
Old Sep 28, 2010 | 02:04 PM
dmurph83's Avatar
I put 15" wheels on my JK and while they fit with no issues, when I went to get my tires mounted and balanced, the guy said he couldn't properly do it because there wasn't enough room on the outside part of the rim to put a weight. There is not enough room between the caliper and the wheel itself. He said to get it perfectly zero, you need to have a weight on the inside part and the outside. That being said, he balanced them pretty well and I don't have any issues, but if I had to do it again I'd probably go 16" just so there's enough room for the weights.
Old Sep 28, 2010 | 02:08 PM
Venom19's Avatar
Thats what "stick on" weights are for! I've had em on my SRT10 for 2 years, and it goes slightly faster than my JK!
Old Sep 28, 2010 | 02:34 PM
CJ7nvrstk's Avatar
Vet Army
Some 15s will fit fine where others won't without some grinding. Love my 15s. BTW, balancing is NOT an issue with my set up.
There is also a thread around here with a what fits chart somewhere.
Old Sep 28, 2010 | 03:04 PM
07JKRUBI's Avatar
Pros- cheap tires, large selection of tires,
cons- if you ever wat to go to a larger tire the selection starts to get slim. There are 37" - 42" tires out there for 15" wheels but some of them get hard to balance. If you ever want to go to a larger brake kit they will not fi. You need to have at least a 17" wheel.
I am sure there are more pros and cons and with that being said, I have been running 15" wheels and 35"s on my 07 Rubi for a couple of years now and have never had an issue. Now that I have a real lift, I am looking to go to a 38" tire, wich means I have to buy rims again or go with a 37" or stay with a 35". If you know for sure you will not go to a tire larger then 35" I say go with a 15" wheel and enjoy the tire savings and don't look back. If you even think you might consider going bigger then 35" go with a 17".
Old Sep 29, 2010 | 07:43 PM
Jvic's Avatar
Thanks for the info guys
Old Sep 29, 2010 | 08:42 PM
ericsurfffs's Avatar
ive heard people say divide the tire size in half and that is the best rim size. I dont like the 15 personally because it feels too squishy on the road
Old Sep 30, 2010 | 08:19 PM
karls's Avatar
15s for sure. again- tires are easy to find for them and simple to size up, ex: 37x14.5, not 305/50/18
