15" wheels on a JK
Old Jun 11, 2007 | 03:32 PM
BRET901's Avatar
Default 15" wheels on a JK
ive seen several Jk's with 15" wheels is there anything special you have to do to make them fit or a certain backspacing, the wheels i want are 15x8 with 3.25 backspacing.
probably going to go with 33x12.5x15 procomp extreme mud terrains
Old Jun 11, 2007 | 04:59 PM
corey3589's Avatar
I have the Pro-Comp 97s 15X8 and I think the BS is 3.75".
Old Jun 11, 2007 | 05:10 PM
BRET901's Avatar
is it a real tight fit? do you think half an inch backspacing would make it not fit.
Old Jun 11, 2007 | 05:31 PM
usmcdoc14's Avatar
I have your typical black "D" window style in 15x8 with 4" backspacing and they fit fine.
One of the mods should make a "FAQ" sticky with this
SLICKWILL's Avatar
15's are tight but look great mine are 15x10 with a 3.75 BS... i lost a lot of wheel weights because how small the are, but over all i would not change them
Old Jun 11, 2007 | 05:32 PM
usmcdoc14's Avatar
no dude, back spacing is from the BACK. so you would in essence have .5 MORE than him. where I have .75 LESS. so yours would stick out more and have more clearance from the brakes on the inside diameter of the wheel.
Old Jun 11, 2007 | 05:34 PM
usmcdoc14's Avatar
what kind of wieghts are you using to lose them? stick on the inside ?
I "usually" run like 10oz of steel BB's inside the tire but for some reason these 35's balanced easy so I am running your "normal" weights.
Old Jun 11, 2007 | 05:42 PM
SLICKWILL's Avatar
yea stick on ones i need the ones you have
Old Jun 11, 2007 | 05:48 PM
usmcdoc14's Avatar
deflate the tire, pop the bead by driving on it with another vehicle, dump like 6-7 shot glasses of regular steel BB's from walmart in, reseat the bead and try that for a bit. You are running boggers so regular wheel weights may bring the suck as they usually require a LOT.
I am running BB's in Q78 TSL's and some 36" muds on 2 of my vehicles and they are well balanced to ABOVE highway speeds
and if it does not work for you, you can always pull the BB's out with a magnet
Old Jun 11, 2007 | 06:41 PM
nmjk's Avatar
Default Equal
There is a product that large tire shops ( meaning truck/rv tires) use to balance called equal. I don't know a whole lot about it except it works just like the bb's except it is designed for this.
Here is some info. http://imiproducts.com/equal/index.aspx
Not really a plug for them, but against buying bb's at WM.
