16 or 17 inch wheels??
Old Aug 31, 2010 | 04:45 AM
atb1137's Avatar
Default 16 or 17 inch wheels??
i noticed most guys on here are running either a 16 or 17 inch wheel. is there any pro vs cons.. im planning to order pro comp 97's this week. i plan on doin light wheeling if that matters...thanks fellas
Old Aug 31, 2010 | 05:18 AM
derby911's Avatar
I bought 17" wheels becuase I already had 285/70/17 tires on my stock wheels. If I were buying tires and wheels together I would have went with 16" I think you can get a better selection of tires and a little cheaper for the 16"
Old Aug 31, 2010 | 05:28 AM
Ozzy17W's Avatar
I would go with a 16" because the wheels are cheaper, the tires are cheaper and it gives you more sidewall if you want to air down. Also I think it looks better.
Old Aug 31, 2010 | 08:16 AM
kbak67's Avatar
so how does the 16" match up with the computer/spedometer? any issues?does it need to be reflashed?
Old Aug 31, 2010 | 08:18 AM
cppower's Avatar
Only the diameter of the tires will affect the speedo, not the wheels.
Old Aug 31, 2010 | 08:22 AM
Pape's Avatar
it not the rim that affect your computer / speedo, it the complete wheels size.
there is tools around to manage the change in wheels size
I got 18 here and if I want good off road tires I need to go down at last to 17.
