16" vs 17" Wheels
Old Jul 7, 2010 | 05:28 AM
Super1's Avatar
Default 16" vs 17" Wheels
I’m trying to make a decision on wheels. I’m split between these two:
Pro Comp Series 1079 Polished Alloy Wheel Size 16x8" Bolt Circle 5x5 Offset -11mm Back Spacing 4" Hub Bore 83.06mm with 285/75R16
Pro Comp Series 1079 Polished Alloy Wheel Size 17x9" Bolt Circle 5x5 Offset -6mm Back Spacing 4.75" Hub Bore 83.06mm with 285/70R17
Basically 16” vs 17” inch tires/wheels. 17” is more expensive, which makes the choice more difficult.
Anyone have any suggestions. If I get the 16”, will I be sorry later? Are there back spacing issues with either?
Old Jul 7, 2010 | 05:29 AM
beamme84's Avatar
i'd get 16" because tires are cheaper.
Old Jul 7, 2010 | 06:33 AM
07JKRUBI's Avatar
Why not look at the 15". Those tires are even cheaper and the Pro comps wheels fit. Just a thought....
Old Jul 7, 2010 | 06:48 AM
Holyroller's Avatar
Really comes down to economics and appearance. Do you like big tires or big rims?
