17" change to 16" ?
Old Jan 2, 2011 | 07:08 AM
rubiRI77's Avatar
Default 17" change to 16" ?
Tried searching, but can't find it. This is probably a really dumb question so bear with me.
I now have an 07 rubi 2 door. (stock 17" moabs) My question is - when looking at aftermarket rims, could I switch to 16" without any issues? (Kind of like the more tire look) and besides that, they are a little cheaper for wheels, AND tires.
I can't see why not, as many JK's come standard with 16's, but just wondering if there is something I am not thinking of?
thanks in advance
Old Jan 2, 2011 | 07:12 AM
Dozerdriver's Avatar
Yes they will fit fine..some guys are running 15's too. The 15's will rub if the rim is thick from what I have read.
Old Jan 2, 2011 | 07:35 AM
MountainJK's Avatar
If you flip your Draglink for a larger lift they won't clear a 16" rim
Old Jan 2, 2011 | 10:33 AM
rubiRI77's Avatar
OK. thanks teh most lift it will see, is 2-3" so I don't think it will be an issue. Thanks again
Old Jan 2, 2011 | 12:32 PM
AK4Dave's Avatar
thanks in advance
I'm with you.....less wheel / more tire is the look I like. I wanted 15s myself, but when I got my 07' back then there weren't many choices without taking the chance that after ordering them they wouldn't fit. 16's will work fine for you....
Old Jan 2, 2011 | 12:47 PM
nthinuf's Avatar
There may be issues with items such as the TeraFlex Big Brake kit. Likely not an issue unless you move to a much larger tire.
