17'' Enkei RT-6 Wheels
Dont BASH me too hard, just thinking outside the box...These wheels are 17x8'' 5-139.7(5on5.5'') with 0 offset....That being said I would have to get adapters but they also act as a spacers(1-3/8'')....And the wheels are in there Truck/SUV selection and not for some light weight car! What you think....Will they work.....How you like them????
Like I said at only $140 for 17'' Im not to worried about scratching them! Pretty cheap compared to the other companys out there! I would be scared to sratch the say like the AEV plinters.....
the offset is the distance from the back mounting flange from the front to rear. What you need is atlest 4.5" of backspace . you get that by measuring the back mounting flange to the lip of the wheel. With a straight edge laying over the the rim measure the distance from the mounting area that mounts to the rotor to the botom of the straight edge. That is the back space measurement. If you are running stock tires then about 5 or 6 inches of backspcae should be fine.
They'd look great painted black. Then they could be touched up after the rock rash happens.
