17" Wheel Backspacing
Old Jan 10, 2012 | 07:05 PM
JK-Rubi's Avatar
Default 17" Wheel Backspacing
Will aftermarket drive shaft options adversely affect the availability of 17" wheel configurations with 4.00 inches of backspacing? I have been searching, but have been unsuccessful finding 17s in those dimensions that were not beadlocks. Does anyone know of any 17" non-beadlock wheels with 4" of BS, preferably alloy? Thanks.
Edit: Added drive shaft phraseology in the hopes of shamelessly generating a greater response to the above wheel question (if this doesn't work, will have to consider provocative terms normally associated with scantily clad members of the fairer sex).
Old Jan 10, 2012 | 08:18 PM
relayer4u's Avatar
V-Tec has a couple of 17 x 8.5 wheels with 4.25 backspace, the Warlord and Wizard series. Besides those two I have not seen anyone else go less than 4.5 inches on the 17s (I have been looking for a while). You can get Walker Evans street locks in a 4 inch bs , but they are way pricey!
Hope that helps you out.
Old Jan 10, 2012 | 08:51 PM
suicideking's Avatar
X2, most have 4.5"
I know you said 17", but the Dick Cepek DC2 in a 16" has 4.0 backspacing. That would save you money on tires too. Of course, unless you already have them...
I considered the DC2 when I got my wheels, but didn't because I wanted the 4.5".
Old Jan 11, 2012 | 06:43 PM
JK-Rubi's Avatar
Thanks guys. You're somewhat confirming what I've noticed - for some reason, 17s with 4.0" backspacing non-beadlocks are difficult to find (at least for me). I have seen 16s with 4.0" backspacing, but not 17s.
Anyone know of other 4" BS options in a 17" wheel, or why they're not that common?
Old Jan 11, 2012 | 07:09 PM
OutlawJK's Avatar
That's why I bought the V-tec wizards
Sent from my iPhone
Old Jan 11, 2012 | 07:11 PM
OutlawJK's Avatar
I wanted Walker Evans but
I got 5 of vtecs for the price of 2 WE's
Sent from my iPhone
Old Jan 11, 2012 | 07:45 PM
JK-Rubi's Avatar
Are these 17" with 4" backspacing?
Old Jan 11, 2012 | 07:57 PM
JK-Rubi's Avatar
Originally Posted by Rexacon
Get black rock soft 8s 17x9 there are 4" bs
They look like steel wheels, or are they available in an alloy?
Old Jan 12, 2012 | 04:09 AM
OutlawJK's Avatar
17 with 4.25
Sent from my iPhone
Old Jan 12, 2012 | 08:48 AM
BKGM Jeepers's Avatar
Depending on rim width there are plenty out there.
For example a 17x9 wheel that I ran had a 12mm offset. This is the same as a 4" back space on a 9" rim (divided by 2, a zero offset is 4.5" backspacing). 25mm is about 1" in the rim world, so you can work both metric and standard offsets. I ran 4" just fine and now run a 3.5" backspace.
Tons of Pro comp rims can meet your needs. Then there are higher end ones and cheaper ones. Beadlocks too.
