18" to a 15" wheel
Old Feb 19, 2013 | 03:02 AM
  #21
sgtkersh's Avatar
I have 15" MB TKOs and 33" Duratracs. It's a great look and they fit fine with my 2" lift. I just drive about 1k miles round trip to the Catskills and overall it was a good ride.
Old Feb 19, 2013 | 03:57 PM
  #22
jd2010jk's Avatar
Originally Posted by GJeep
I don't think that this is a stupid question. Every part of the suspension has some effect.
Yes, rim size affects ride, the only question is by how much.
The effect may be small and many times not actually felt.
Tires twist whenever the vehicle turns. A taller sidewall means more twist. This results in a bit "mushier" steering, which, if felt, it would be on roads (and typically at higher speeds) rather than offroad.
This also depends on how pliable are the the sidewalls, and on tire pressure -- and these two have a greater effect than sidewall size.
Still, I expect the drastic change that the OP talked about, from tires on 18" to tires on 15", to change the steering feel.
As for the weight saved by smaller rims, it is more or less "gained" back by the increased tire weight.
17" is a good average for tire availability, range of tire prices, and looks.
Usually, they will be easier to balance vs smaller rims with taller sidewalls.
Thanks for the reply, I think I'm going to be going with either 16" or 17" rims, the 18" rims just are not all that practical.
Old Feb 19, 2013 | 04:14 PM
  #23
DesolationMania's Avatar
And there's no problem clearing the calipers on this model?
Old Feb 19, 2013 | 04:37 PM
  #24
sgtkersh's Avatar
I don't have any problems with the calipers. Steel wheels usually do, but many alloys fit fine. Discount Tire Direct has a good deal of 15" wheels that will fit without issues.
Sent from my iPad using Tapatalk HD
Old Feb 19, 2013 | 04:44 PM
  #25
zstairlessone's Avatar
Think about 17" wheels, with a 35 (and larger - you know it will happen) you will need to start thinking about braking power increases, specially if/when you regear. I really don't think you can put a larger set of brakes on with 15s and maybe not 16s.
Old Feb 19, 2013 | 04:52 PM
  #26
951JEEP's Avatar
35x12.5 Pro Comp MTs on Pro Comp 15x10 152s
Name:	lifted on 35s.jpg
Old Feb 19, 2013 | 06:16 PM
  #27
SHAKE IT's Avatar
Originally Posted by rockyjk07
Im running 15s because i do like the old school look of smaller wheel and big tires mine are procomp soft 8's 15x10 with 35x12.5 hankook dynapro mts
Looks great, LOVE that look
Old Feb 19, 2013 | 06:31 PM
  #28
SHAKE IT's Avatar
WOW , Awesome guys thanks for all the info. I have a lot more thinking and planning to do on my tire situation. The one thing I do know is the 18's gotta go.
Thanks again,
SHAKE IT
Old Feb 19, 2013 | 06:42 PM
  #29
Infinity's Avatar
I too am running 35's on 15x8 wheels. I love the look. I have had then for over 2 years and they ride just fine and are amazing when aired down. My only complaint was when I bent my tie rod and had a hard time finding a beefier one. I ended up going back to factory though I think the rock krawler tie rod has been proven to fit.
I also tend to find it harder to clean the inside of the wheel after offroading as the tolerance between the caliper and rim is really tight. Not a big deal though.
I did it to save money when I had to replace tires.
Old Feb 21, 2013 | 05:35 PM
  #30
rays0852's Avatar
Ditched my factory Sahara 18" wheels and Duratrac 33s tonight for:
15 x 8 MB TKOs
35 x12.50 x 15 BFG KM2s
I have a little anxiety about it but the guy at DTD assured me they will work fine.
