from 19 to 12 mpg...Is something wrong?
Old Mar 22, 2010 | 09:14 AM
VEGASSMAN's Avatar
Originally Posted by spinlock
Did you upgrade to 4.10 gears in your Sahara?
Most Sahara's have 3.73s from the tow package.
The auto doesn't provide the flexibility of the manual when it comes to gears.
I average ~16 MPG with 35's, auto and 5.13s at 75-80 MPH.
I've done a bunch of research on this...from everything I've found, the stock axle ratio for X and Sahara package is 3.21. 4.10 was the optional tow package and standard ratio for Rubicons. I have seen reviews referencing the 3.73 axle ratio though.
Much confusion....
This was the comment listed on a couple tow capacity charts I found: "**AHT Trailer Tow Package not available with 3.21 Axle Ratio"
I ordered my build sheet from Jeep to verify before I go with gears...but I'm assuming my (and all) tow packages came with 4.10s.
After looking further, it seems like a few sites suggest that the 3.21s were standard only in the 6sp MT, and all of the 4sp ATs came with 4.10s...
TRANSMISSION: NSG 370—MANUAL, SIX-SPEED OVERDRIVE
Availability…..................................... .................................................. ....................................Std.—All models
Description....................................... ...................................... Synchronized in all forward gears and reverse,
multi-rail shift system with top-mounted shift lever
Clutch............................................ ........................................Hydraulic actuation
Gear Ratios
1st….............................................. .................................................. .................................................. ....... 4.46
2nd….............................................. .................................................. .................................................. ....... 2.61
3rd….............................................. .................................................. .................................................. ....... 1.72
4th….............................................. .................................................. .................................................. ....... 1.25
5th….............................................. .................................................. .................................................. ....... 1.00
6th….............................................. .................................................. .................................................. ........ 0.84
Reverse........................................... .................................................. .................................................. ..... 4.06
Axle Ratio............................................. ................................................3. 21 Std., 4.10 Opt. (Std. on Rubicon)
Overall Top Gear.............................................. .....................................2.69 Std., 3.44 Opt. (Std. on Rubicon)
TRANSMISSION: 42RLE—AUTOMATIC, FOUR-SPEED OVERDRIVE WITH VARIABLE LINE PRESSURE
Availability………………................................ .................................................. ......................................Optional Description....................................... ..............Electronic governor, electronically controlled converter clutch
Gear Ratios
1st….. .................................................. .................................................. .................................................. . 2.84
2nd….............................................. .................................................. .................................................. ....... 1.57
3rd….............................................. .................................................. .................................................. ..........1.0
4th….............................................. .................................................. .................................................. ........ 0.69
Reverse........................................... .................................................. .................................................. ..... 2.21
Axle Ratio............................................. .................................................. .................................................. 4.10
Overall Top Gear.............................................. .................................................. ...................................... 2.83
My research was based on Google searching "jk jeep wrangler unlimited sahara axle ratio" and going through the 1st 4-5 pages of results.
Note: When you get to a page, if you hit Ctrl+F (this is find function in Windows), you can search the pages for "ratio" and click through the entire site to find every time the word is used...
Old Mar 22, 2010 | 09:19 AM
redrockin7's Avatar
Originally Posted by TEEJ
Using a programmer, etc...to correct for the gearing and/or tire changes can fix all that of course.
He has a programmer, so that's not the problem...
Old Mar 22, 2010 | 09:32 AM
Socal Tom's Avatar
In 2007 all automatics got 4.11 gears. My 07 sahara has them. Old rule of thumb was for every inch you go up take off 1 mpg.
With lift and 35s the expect 3 to 4 lower. Have you corrected the speedometer? You will probably improve mileage by taking off od until you can regear.
Old Mar 22, 2010 | 09:33 AM
NeverStock's Avatar
As your instruments (Like the ODOMETER and SPEEDOMETER) take the rpm off of the tail shaft, when you regear, (And/or get larger tires, etc...you change the rpm for any given speed, and this makes the miles you thought you drove, and the speed at which you thought you drove them WRONG.
So, its POSSIBLE that you went more miles than the odometer said you did, and, that you were going faster than you thought you were, both of which, or either, will make you hand calculate a loss in mpg.
The dash read out would of course be fictional as well, etc.
Thanks TEEJ...
I do have the superchips, and recalibrated for the 35's. I guess I need to start a "5.13 gears fund" !!!
Old Mar 22, 2010 | 09:36 AM
CitadelJeep04's Avatar
For example, if you went from 32's to 35's, you dropped your RPM at any given speed by ~ 8.6%
If you went from 3.73's to 5.13's, you INCREASED your RPM at any given speed by ~ 27.3%
The net change in RPM is ~ 18.7% higher RPM at any given speed.
That would make you drive SLOWER than you thought, but drive a shorter distance than you thought as well.
If you were getting, say 14.7 mpg on 32's and 3.73's.....your apparent mpg might GO UP to perhaps 16.3 mpg or so on 35's and 5.13's.
Food for thought.
I did use a programmer, and my mph reading is accurate. So, I did go from 14.7 to 16.3 with no other change than gears. Using the same Superchips 93 tune for each, all I did was change gear ratio in tuner. Increase MPG by 1.6 by going from 3.73's to 5.13's.
Old Mar 22, 2010 | 09:38 AM
NeverStock's Avatar
Originally Posted by Socal Tom
In 2007 all automatics got 4.11 gears. My 07 sahara bs them. Old rule of thumb was for every inch you go up take off 1 mpg.
Thanks Tom!
I have been turning the OD off quite a bit. Does it hurt the engine in any form or fashion to run with OD off for an extended period of time? Is it harder on the transmission, or is it actually easier as it is not continuously shifting in and out of OD.
Also sounds like it is a crap shoot to what gears I got on my 09 sahara with towing package.
Thanks for the input all!
Keep em coming!!
Old Mar 22, 2010 | 09:47 AM
ZoSo-Green's Avatar
For an '09 you most likely you have 3.73's. (sorry)
I am pretty sure the 4.10's were only offered in '07 on all but Rubi's
With an auto the 3.8 is struggling on the 35's and burning more gas in
the process.
You are going to have to go to a 4.88 or 5.13 to be satisfied.
Old Mar 22, 2010 | 09:51 AM
bkw's Avatar
bkw
If you have an AT, then being in the 12's is on the low side, but nothing out of the ordinary.
Few questions:
What size did you input when calibrating your tire size? 35's are rarely ever really 35" tall. Double check your speedo with a GPS. My 35's measured out at about 33.1".
Are you unknowingly driving around with your airconditioner on? If it's set to "Mix" or Defrost, then your A/C kicks in automatically.
Whats your average speed when on the highway? I find that anything over 65mph and I'm burning gas faster than taco bell.
I'm at about a 80% highway 20% local road mix right now and I'm getting 13.5mpg's on my JKU with 35's, armor, lift, kids, etc.
Old Mar 22, 2010 | 09:52 AM
FrostByte's Avatar
I have a 2009 Sahara and the 3.73 gears were mandatory when adding the automatic option. You also get the 3.73 gears when adding the tow package. Same is true with the 2010 if you go to jeep .com and build a Wrangler it will force the gear changes. There is no option for 4.10 gears (maybe by special order only, but not an option on the website). I "believe" 2007 was the last year 4.10 gears were an option.
Socal Tom's Avatar
Originally Posted by NeverStock
Thanks Tom!
Keep em coming!!
Turning OD off won't hurt the trans/engine as long as you keep the engine rpms reasonable. It may even extend the life of the transmission. With the tall tires, the bands in the trans are stressed harder trying to hold the trans in OD at lower Rpm than was originally intended. Turning it off will make it easier on that band, which is usually the weak link in an auto.
WIth mine I run about 2K rpm at about 65, if you stay south of 3k for normal driving then the engine will be fine. It probably would like to be at about 2500 rpm anyhow.
Tom
