2.5 and 35's
Old May 21, 2012 | 10:27 PM
Schwheelz's Avatar
Default 2.5 and 35's
Ey guys I just installed my 2.5" tf bb tonight and I was reading that 35's will not fit on the four doors. Is this true? Because I have 5 wheels and tires on their way right now, and they are gonna fit. Right?
Old May 22, 2012 | 04:40 AM
mango10's Avatar
I don't have the bb I have a 2.5 coil lift n I have no issues only small problem was I went with mud grapplers n the side biters would rub the sway bar
Old May 22, 2012 | 04:49 AM
4W-Jive's Avatar
as long as you have enough backspacing on your wheels you should be good, worse comes to worst just do a little fender trimming
Old May 22, 2012 | 05:15 AM
Fivepack1966's Avatar
Yes they'll fit, depending on your back spacing. I'm running an AEV 2" bb and 35's no issues with 3.75" back spacing.
Old May 22, 2012 | 05:55 AM
wayoflife's Avatar
JK-Forum Founder
being that you have new wheels coming, is it safe to say they have 4.5" of backspacing or less? if so, you should be good for the most part clearing your 35's. where you will have a problem is with the rear corner of your pinch seam as it will make contact with your tread when off roading. fortuantely, cutting the corner off is easy to do and can be done in minutes with a hacksaw or sawzall.
Old May 22, 2012 | 06:05 AM
Schwheelz's Avatar
Yes I have 4.5 inch backspacing and 1 1/4" spacers do there is definitely plenty of backspacing thanks for the spedy replies guys
Old May 22, 2012 | 06:06 AM
Schwheelz's Avatar
Any write-ups on trimming the pinch seam?
