2.5 lift on automatic will I ..
4 door you only need the front drive shaft. 2 door needs both.
Any quality kit will come with brake line relocation brackets. Depending on your wheels, you might need wheel spacers. If the 12's are like the older ones a little trimmimg of the pinch seam may be needed. Make sure you get an AEV procal to reprogram the computer for the tire size.
You would need at least:
Brake line extension brackets
Rear track bar bracket,preferably the ones that bolt to the frame
Exhaust extensions to help clear the driveshaft issue
Procal to calibrate your speedo & tire size
Move your rear sway bar links to the front and get longer sway bar links for the rear.
2" bump stops
Some quality lift kits offer the parts I mentioned except for the Procal..
2" bump stops
