2.5 lift kit
So let me see if I get this straight:
To run 33s on factory rims, it is possible to without any lift but need spacers, not sure if any rubbing will occur?
To run 35s on factory rims, it is possible to with 2.5 inch lift but need spacers and may have slight rubbing in extreme conditions.
Running 3 inches of lift with 35s should eliminate all rubbing
i just installed the black diamond 3" lift, like other kits it came with new rear sway bars and i used the factory rear sway bars on the front(which incidently were rubbing the tire prior to touching it) anyway..the kit came with a relocation bracket which i installed and it forced the flexible braline lower to extnd as my jeep flexs, however..the directions told me to carefully manipulate the bark line to avoid rubbing, so now from the top of my sway bar to my manipulated brake line is less travel than i have to the bump stop. I did not get real radical with my bending bu ti definately will have issues off road the parker store has fittings and such but i cant be the only one..am i?
