2.5 RC Springs shocks
Old Mar 15, 2013 | 12:00 AM
Mexican_Guard's Avatar
Veteran: Coast Guard
Default 2.5 RC Springs shocks
Sorry i have looke and cant find the answer,
i just want to know if i bought the RC 2.5 Spring and shocks what else would i need to finish the lift kit? i know i can just put those on and call it a day..right? Thank you for the help!
Old Mar 15, 2013 | 12:02 AM
this is what i was thinking to get:
www.ebay.com/itm/Jeep-Wrangler-JK-2-5-Suspension-Lift-Kit-w-Shocks-2007-2012-/370716464203?pt=Motors_Car_Truck_Parts_Accessories &fits=Submodel%3ASport%7CYear%3A2012%7CMake%3AJeep %7CModel%3AWrangler%7CEngine+-+Liter_Display%3A3.6L&hash=item56506c544b&vxp=mtr# ht_1049wt_1162]Jeep Wrangler JK 2 5[/url]
also its for a 2013 2 door..
Old Mar 15, 2013 | 02:48 AM
Jonathan_JK's Avatar
You can just slap it in but it's not going to ride like stock. Rough country tends to be a little rough. But that's how I like it so no big deal for me. You might notice that the steering is going to be more sensitive due to the castor angle.
Old Mar 15, 2013 | 03:21 AM
maine07jk's Avatar
I can only tell you about my experience, but when I put on my 2.5" RC I found the ride to be softer.
The only thing you will need is some brake line extensions and a set of front sway bar quick disconnects.
Old Mar 15, 2013 | 03:51 AM
mangotangojk's Avatar
I have the RC 2.5" coils and shocks you might want flat fenders if you are running 35s I broke both of my rear fenders from wheeling.
I am going to get a better lift in about 6 months, when I return from Japan. It's good don't get me wrong but I want a 4" lift from TF! Good luck!!!
Old Mar 15, 2013 | 04:56 AM
djbrew's Avatar
I put this one on my 2012 2 door when I had it - www.extremeterrain.com/rough-country-325-lift-jk-perf693.html]Rough Country 3.25 in. Lift Kit (07-13 Wrangler JK) PERF693 - Free Shipping over $75![/url]
For a few extra bucks (any maybe less if any of the forum vendors carry it) you could get Everything you need.
Old Mar 15, 2013 | 04:57 AM
Sebastian's Avatar
When I bought my 2007 JKUR a few weeks ago it already came with the RC 2.5" coil kit w/ 2.2 performance shocks. As far as I can tell there had been no brake extensions installed and there is also no trackbar bracket.
However when I do an extended turn, let's say from a stop signal, I get a deep sounding "clack" when I turn the steering wheel to the right and another "clack" when I turn it back straight. I am not sure where that comes from and what causes it though.
Old Mar 15, 2013 | 05:24 AM
maine07jk's Avatar
Bad tie rod end or ball joint??
Old Mar 15, 2013 | 05:29 AM
Sebastian's Avatar
And I forgot to say that I like the stiff ride of the RC 2.5" kit. It is not too rough but reduces body roll and feels quite comfortable a higher speeds.
How could I find out what it is and do you think I can fix this myself?
Old Mar 15, 2013 | 05:51 AM
maine07jk's Avatar
Look under the front and have someone turn the wheel. See if you can feel, see, or hear where it pops. If you don't have extra hands, I would swing it by a garage and they should be able to tell you. If you are mechanical...yes, you can fix any of the above with the correct tools.
