2.5 teraflex lift rattle????
Old Jul 20, 2012 | 09:42 AM
  #21
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by djcamis
Shocks ruled out, I am 99.8% sure it is the break brackets, now how do u take them off?
You'll want to leave those rear brake brackets on. Can you post a pic showing how your installed them?
Old Jul 20, 2012 | 09:47 AM
  #22
TXBeachJK's Avatar
Retorque everything. I had the same issue with rattling after I installed my TF 2.5 coil lift.. Mine was a loose shock, control arm, and front track bar. Retorqued and haven't had any issues since.
Old Jul 20, 2012 | 10:13 AM
  #23
Its_a_JK's Avatar
Sponsoring Vendor
Epic-Addictions Representative
Check to make sure your front coil springs are all properly seated in the perch, if they rotate even a few degrees you will get noise since they are not flush against the index slot (for lack of a better term).
Old Jul 20, 2012 | 11:30 AM
  #24
Charlie Mike's Avatar
Uh oh. Now I'm worried because I took mine off. lol. Why so, Teraflex?
I used two vice grips and anything I could to pry those brackets open as much as possible. Being careful not to damage the brake line. After that, sprayed it down with some WD-40 and started at one end of the bracket and just started pulling nice and easy down the entire length until the brake line was free.
Old Jul 20, 2012 | 11:32 AM
  #25
Oh. Just realized you were talking about the rear brackets.
I took off my front brake line brackets from the brake line. Don't recall there even being rear brake line brackets. Hmmm...
Old Jul 20, 2012 | 11:33 AM
  #26
TeraFlex's Avatar
Now I was talking about the rears are you talking about the fronts? If so then there's nothing wrong with doing that.
Old Jul 20, 2012 | 12:12 PM
  #27
djcamis's Avatar
Oh mr. Teraflex we are speaking about the front break brackets
Old Jul 20, 2012 | 12:18 PM
  #28
djcamis's Avatar
The front track bar is the one that's under the steering wheel bar right? That one seems a little loose. But I am pretty sure it's the break brackets, cause it sounds just like when I move it a little to when I go over a bump. I just don't see how it be moved to make a sound?
Old Jul 20, 2012 | 12:22 PM
  #29
djcamis's Avatar
I played around with the springs, they seem to be perfectly flushed.
Old Jul 25, 2012 | 03:34 PM
  #30
This should help:
Project-JK.com - Jeep JK Wrangler Resource» alignment
