2.5" TF additional parts
Old May 9, 2010 | 03:22 PM
couchpotato's Avatar
Default 2.5" TF additional parts
If somebody has a link for this please post it for me, cant find it.
bought TF 2.5" coil w/ shocks, do i need any other items while im ordering from northridge? front adj. track bar? any additional arms? wheel spacers (running stock tires and rims for now) any help would be great, gotta spend fast before wife changes her mind.
Old May 9, 2010 | 03:26 PM
jvalason's Avatar
The only thing extra I got when I had my 2.5 was the rear trackbar bracket and some swaybar discos
Old May 9, 2010 | 03:28 PM
are the rubicon disco's not enough or am i missing something
Old May 9, 2010 | 03:29 PM
JayhawkJeep's Avatar
Veteran: Navy
The only thing you have to have are spacers (if running the stock tires). Went 7 months without track bars. They are very nice to have but I would not consider them critical. Also if you plan on putting on disc's now would be a good time since to the stock ones come off anyhow.
Old May 9, 2010 | 03:32 PM
jvalason's Avatar
I ran stock wheels with rubi take offs and never used spacers and never had any rubbing problems. I had the Rough Country 2.5 lift though...
Old May 9, 2010 | 03:36 PM
well i have the extra money to spend so should i put a front track bar on it as well? and you said i have to take my stock disco off? so my push button wont work unless i get new disco's?
Old May 9, 2010 | 03:41 PM
jvalason's Avatar
You dont need a front track bar...if you want one you can get one but its not needed. I dont have a rubi so I cant help you with the e-disco.
Old May 9, 2010 | 03:46 PM
stlfan06's Avatar
Your e-discos will work fine.
I would allocate your extra $ towards:
1) Spidertrax wheel spacers (if you don't plan on purchasing new wheels with less backspacing)
2) Adj. front trackbar
3) Adj. front lower control arms.
Old May 9, 2010 | 03:47 PM
what do you mean by disc's and stock coming off?
Cpt. Flapjack's Avatar
Your disconnect will be fine. You get new rear swaybar links and move the factory rear links to the front. This allows the e-disco to be used without flipping at max droop.
You will need wheel spacers or the rear wheels will rub the new swaybar links when you flex. The only other thing I would suggest is longer break lines. Even with the rear brackets, the lines pull pretty tight with the additional travel of the Teraflex shocks. I replaced mine just to be safe....
