2.5"TF BB with RUBI COILS?
Old Jan 3, 2009 | 10:31 AM
Infidel616's Avatar
Originally Posted by jkkat
Being i have run this type of setup for a year, I have only had problems with the right rear shock due to trying to extend it too far BUT as long as you have installed the bump stops it will be fine.
If you do not have a bunch of weight to put in back it will ride stiff.
4Dr springs gave me an inch before adding all my stuff.
thanks, thats what i was thinking. I have the bump stops so i should be fine. It just seems like a simple mod to me that will give me exactly what im looking to gain for very cheap. I would like to maintain the same height or slightly higher than i have now with a heavy set of bumpers and possibly gain some stiffness to aid in stopping, etc. I currently dont have heavy bumpers so my questions were in regards to adding springs before the bumpers and if i would suffer any of the before mentioned issues.
I think that is the biggest complaint with my current lift is that when i have to brake hard the front end dips pretty bad and makes it a bit unstable. its not horrible but is worth the few dollars it would cost to swap springs
