2.5 TF COIL needs Track Bars?
Ive trolled the forums but cant realy find what im looking for. I dont mind spending the money but i need to know.
If i get the Tera Flex 2.5 lift with a 34 bfg km do i need new brakelines and front and rear adJ TRACK BARS AS WELL AS A STEERING STABILIZER? I JSUT WANT TO MAKE SURE I DO MY LIFT RIGHT. kEEP IN MIND THAT WHEN I CAN QUIT DRIVING MY RUBI AS A dd IM GOING TO LIFT IT HIGHER sorry for the caps to lazy to retype. Do i need these parts to avoid tearing up my rubicon?
Thanks,
Matt
Thanks,
Matt
Thanks,
Matt
Thanks,
Matt
What wayoflife said.
The front will be offset 1/2 on the drivers side. Which means to have it perfectly centered you would make an adjustable trackbar 1/4 longer than stock. I put one on mine, but not right away. It was fine without it, just make sure you center you steering wheel by adjusting your draglink. I just took a 15mm wrench with me on a test ride and stopped beside the road and made an adjustment until it was right. I replaced my stabilizer, but just because I wanted the Teraflex one to go with my shocks. I've heard it's not necessary. The rear comes with a bracket so an adjustable trackbar is not needed, but I also put one on anyway. Why, idunno, I guess I like spending money on my Jeep
Thanks HellBilly and WOL for answering this for me.
Rubican! if you have any more questions/concerns please give a call monday. If you need to talk to me sooner I can PM my cell # to you.
I have this kit, and my front axle is off center. I've developed a decent vibration at around 57 mph. I am going to install a front trackbar to square things up a bit and see if that helps my vibration.
thanks guys, i actully wheeled with a guy today in my club that h as several terflex kits. He said it wasnt needed but after reading here and looking around id rather play it safe and go ahead and get the trackbars. I hear alot that the highway ride is better then the stock. Is that right?
