2.5 vs 3.5 vs. 4 with 33's
Hello All,
I have been lurking for a couple of weeks now, reading and searching everything that I could about lifts, wheels and tires. My account got activated last nite, so here goes my first post! I am shopping for a lift.:crazyeyes: I am planning on running 33's for a while (1 - 2 years) until I can upgrade gears (3.73 currently) for 35's. 35 will probably be my max. I'm sure everyone is rolling their eyes, saying "Yeah, right"!:rollingeyes: Unfortunately, I am torn between a few different packages...
My questions are...
Thank you in advance for all of your insight and information! Sorry for the long winded post, I am usually much more concise. |
why would you want 4" to clear 33s?
Welcome to the forum. :clap:
Here's a link to a Show Your 33's thread... Lots of lifts to check out on 33" tires. You'll soon see that most people run 2-3" for 33s. More then that and you get lets of empty wheel well which can look disproportionate. Planman's plan is pretty solid since you'll be on slab most of the time. :yup: Also - for the mostly pavement route, I'd say BFG ATs are great option to check out. |
answer
2.5 BB with 33's looks perfect. . . Body lift 1 in for 35's or if you don't plan on going crazy don't use the BL, 35' will clear with proper back spacing.
If you lift higher you open up more things you will HAVE to buy. . . ie shafts, adj track bar. |
Originally Posted by planman
(Post 926495)
For what you have said will be your planned use, either a 2" or 2.5" BB (coil spacer lift), a 1" body lift, or trimmed or Xenon flat flares would be the most appropriate.
More than 2.5" with 33s will look bad imo. More than 2.5" on stock control arms will not handle like you'd want for a rig that is 90 percent on asphalt. I'd suggest you don't mess with your suspension unless you are going to offroad more. Just do the 1" body lift, flat flares or trimmed flares and call it a day until you are ready to run 35s. Also, if you are concerned about a soft ride, stay away from load range E tires (designed for full size trucks with large towing capacities). Try to select a load range C tire if you want a soft ride. More than 2.5" on stock control arms will not handle like you'd want? Tell that to all the folks with Unlimited's running 3" & 3.5" on stock control arms. I've got a 3" lift, with load range E 33's, & stock control arms. It looks and rides great though I would rather have 35's under there and will soon. http://i331.photobucket.com/albums/l...Jeep/photo.jpg
Originally Posted by bigbluejk
(Post 926482)
If I were you I would go with a 2.5" BB and a good set of 33's and some aftermarket wheels or wheel spacers. |
Originally Posted by riverzendz
(Post 926639)
How will a 2.5" lift + a 1" body lift with 33's look any different than a 3" suspension lift with 33's? Especially with the addition of flat fenders? Yet one looks good and one doesn't? :what?:
More than 2.5" on stock control arms will not handle like you'd want? Tell that to all the folks with Unlimited's running 3" & 3.5" on stock control arms. I've got a 3" lift, with load range E 33's, & stock control arms. It looks and rides great though I would rather have 35's under there and will soon. http://i331.photobucket.com/albums/l...Jeep/photo.jpg x2 4" is excessive for what you want (i.e. 33's, fine for 35's). If I were you I would go with a 2.5" BB and a good set of 33's and some aftermarket wheels or wheel spacers. I think jharkins was saying do a 2.5 lift for 33's and ADD the 1in BL when he wanted to run 35's. I ran that setup on my 35's for a while. |
Can't help with a comparison to the others, but I have the Teraflex 2.5" coils with shocks. I'm happy with this system, but I would not agree that it's "soft". My seat of the pants feel says it's firmer than stock, but I only had it installed a few weeks before upgrading my tires. I went with BFG AT 295/75-16 (33.2" actual diameter) Load Range D tires and am running them at 26PSI cold. Seems just about right, but again firmer than stock by a good measure.
I also upgraded from my 3.21 gears to 4.56's. With 3.73's and an automatic (?) I wouldn't bother until you decide to go to 35's. Hope this helps. Ron |
riverzendz, Is this a picture of 33's on a 3.5" lift ( 2.5" + 1" bl ) or 2.5"? I think this looks really good! I was afraid that there would be too much open space. m(a)ce, I have lived on that 33's page for the past 4 nights. I found a lot with 2.5", but want to see with 3.25" - 4". All, Thanks so much for the input. I am ruling out the 4" Rough Country, but I still feel that the Rusty's kit with shocks, coils (2") and adjustable track bars for $550 + $65 shipping is the best solution I've seen so far. I am not a big fan of spacers. Plus, I will have the adj trackbars when 35's do show up. http://rustysoffroad.com/mm5/merchan...ry_Code=JKKITS I am planning on ProComp 7089 or KMC Enduro 16x8 with 4.75 bs. (Soon as they are in stock!) Toyo Open Country AT's in 275/85x16. |
Originally Posted by Roxster
(Post 927058)
I also upgraded from my 3.21 gears to 4.56's. With 3.73's and an automatic (?) I wouldn't bother until you decide to go to 35's. Hope this helps. Ron It is a 6 speed. |
Here is a pic of 33's on a 3" setup, but should be a good idea.
Too much gap? 3" with 33's And a 2" Rusty's http://my.project-jk.com/data/500/S5000972.JPG I finally found an unlimited with 3" - 3.25" of lift on 33's. http://my.project-jk.com/data/509/IMGP0415_Small_.JPG Thanks again everyone! |
