2.5 vs. 3 inch lift
Just me but I would go ahead and change the springs to match the shock replacement. Before doing the change and since both sets of springs are TF, I would check to see if the part numbers of the springs are actually different. Technically, they should be different but I'm struggling to understand the reason why TF would design/develop/produce a different 2.5" set and 3" set of front and rear springs. Seems kind of silly, so I'm kind of suspecting they may actually be the same springs.
To the OP's original question, I've heard 2.5-inch lifts risk rubbing at full extension off-road. So, if you wheel your Jeep at all, I'd err on the side of adding the new springs only AFTER verifying they're a different part number.
Actual height is what you need to look at. Rarely do coil lifts give you what they are advertised at. Most will give you more. I would measure what you actually have now and what you get if you install the longer coils. If you actually get into the 3.5" area you will notice some difference in ride mainly in your steering.
Ended up keeping 2.5 inch springs. I find that mew suspension arms and shocks work better with the shorter springs. S/T3 springs are 3.5 inches, I measured all around with both sets and 2.5 inch are exactly 1 inch shorter.
Going from 2" puck lift to a 3" spring lift with brackets
Hey Everyone: Just wondering if I'm going to not notice much of a distance in height for the cost?
Anyone here with a 3"?I'm on 35's
Reason I'm deciding on 3" is I like the thicker stance. So i don't want to lose that.
I don't ever plan on going to 37"
I should be able to feel a difference right? getting in and out as well as on road?
Someone recently told me with puck lift I'm probably actually getting only 1.5" height...
I'm about to take the plunge and would love some feedback on this. Thank YOU!!
A 3" spring lift will wash out some caster on front axle if you do not have adjustable control arms. The front driveshaft angle will need to be looked at as it will be close to 3 degrees difference if not more. You will need to adjust tracbar to keep axle centered and steering to straighten out the steering wheel. If you have an adjustable axle side tracbar mount on rear axle, move the tracbar to the top hole as will improve roll center (body roll)
RickLB (05-07-2023)
