2.5" vs 3" lift
Old Feb 14, 2014 | 09:33 AM
justinwells3232's Avatar
Default 2.5" vs 3" lift
i have a 13 jku going to run 35x12.5x17. dont do rock climbing yet but light trails for now. any advice on which lift would be better.... i want a smooth ride but be able to go off road with comfort. and if i put 16" wheel on with 35" tires will it be the same height as the 17" on 35"s with the lift kit.
Old Feb 14, 2014 | 09:40 AM
BlikitSchmikit's Avatar
Vet Army
There are a couple of STICKYS at the top of the Modified Tech forum https://www.jk-forum.com/forums/modi...-lifts-288269/ and https://www.jk-forum.com/forums/modi...bie-has-18617/
You will likely be pleasantly surprised at the wealth of information and knowledge in those two threads alone
good luck w/the build and welcome to the forum
Last edited by BlikitSchmikit; Feb 14, 2014 at 09:42 AM. Reason: adding links to stickys
Old Feb 14, 2014 | 10:09 AM
Rock Krawler Suspension's Avatar
Former Vendor
A 35" tire will fit under a 2.5" kit just fine, take a look at some of our systems, you may find something that suits your needs. A 2.5" stock mod or flex system would probably do everything you want it to do! We're here to help if you have any questions!
RK
Old Feb 14, 2014 | 11:20 AM
mpkelley20's Avatar
I ran a 2.5" on mine with 35's for almost 2 years with no issues. It looks great with that setup. I now have a 3.5" RK lift but kept the 35's. While it looks OK, 37's would look better as it would fill out the wheel wells a bit more. Depending on what lift you go with, keeping a "smooth" ride might be difficult. Getting a more complete lift or one that allows for some adjustments to caster will help (I prefer adjustable control arms over drop brackets).
As for 16's vs 17's...the height will be the same. The 16" tire will just have a little more sidewall protection over a 17". You lose sidewall when moving up in wheel size.
Edit*** also, just noticed you are in Tacoma....take a ride to Northridge and go see some builds in person. It is not a long ride from Tacoma.
Old Feb 14, 2014 | 11:53 AM
brighton's Avatar
Many 2.5" lifts will give you more than 2.5". My RK Max Travel lift netted me about 3.25" in the front, 2.75" in the rear even with heavier bumpers, winch, etc. on my JKU. Certainly adequate for my 35s.
Old Feb 16, 2014 | 07:58 PM
I've decided to go with the Rubicon 3.5 lift kits with twin mono tube shocks
Sent from my DROID BIONIC using JK-Forum
Old Feb 16, 2014 | 08:22 PM
meep97's Avatar
So what made you go with that kit?
Old Feb 17, 2014 | 06:31 PM
4 wheel parts guy.
Old Feb 17, 2014 | 06:34 PM
ronixwrangler's Avatar
RK 2.5 flex and 34's plenty room
Old Feb 17, 2014 | 07:02 PM
Nice jeep.
