2.5BB and 315/75/R17
Old Jul 1, 2008 | 10:04 PM
achi10's Avatar
Default 2.5BB and 315/75/R17
Hey, just bought my new Jeep last week!!! It's freakin' awesome...I purchased it in black --- but damn if I don't like every color out there. Every time I see the rescue green lifted I'm like "sh*t, I should have gotten rescue green". Then I see the silver and "damn, should have gotten silver...". It doesn't stop...every color looks freakin' awesome!!! I love this JEEP!!!
Anyway, I'm going to Off Road Evo pretty soon to put on the 2.5BB --- I'm currently looking for a deal on 35s...
My question is, those with the 2.5BB and 35s, is there anything else I need to do so that I don't rub? The guys over at Evo weren't too clear...
I just want to make sure that I have everythingI need from the get-go so that I don't run into any problems in the future....
TIA!
Old Jul 2, 2008 | 01:51 AM
ZoSo-Green's Avatar
factory wheels?? if so, you might want to get wheel spacers
Old Jul 2, 2008 | 02:30 AM
wayland1985's Avatar
You'll likely rub while off road, so you may want to look into adding a 1" body lift to help with that.
As the previous poster said, a set of spacers are needed if you're running the factory wheels, but I think money will be better spent on just replacing the factory wheels with some Cragar Soft 8's, or an equivalent steel wheel.
Old Jul 2, 2008 | 04:35 AM
-MAW-'s Avatar
at full stuff you will rub big time but if you went w/t a narrower tire 285 75 r 17
it won't be so bad
i have 315/70r17 on moabs w/t spacers & at full stuff wheels straight its ok but turned bye bye bush wackers
a longer bump stop would help but you'll get less articulation or a body lift
you could also trim the fender flare so the part that would touch will allow the tire to rotate
Old Jul 2, 2008 | 04:40 AM
-MAW-'s Avatar
spacers are really only if you don't center your diffs afterwards
i have a set of rusty'r adj track bars and w/t out the spacers you sill just clear the sway bar links
Old Jul 2, 2008 | 04:54 AM
mbsliwa's Avatar
What "car" are you talking about?? You're gonna hurt your jeep's feelings if you keep refering to her as a "car"
Old Jul 2, 2008 | 05:54 AM
jkkat's Avatar
A Jeep Wrangler is NOT a car, Its a Jeep, Its a Wrangler, Its what ever name your call it BUT its NOT a car.
Love RubyDoo
Old Jul 2, 2008 | 06:30 AM
jeeperjkj's Avatar
Can.
Open.
Worms.
Everywhere.
OH, poor kittens.
Congrats on your new JEEP!
Old Jul 2, 2008 | 07:54 AM
axsys's Avatar
i did the rough country 2.5BB and then put on some 315/75R16s. they did rub a lot at full flex, but after i added a 1"BL they barely rub now. if you go with aftermarket wheels, make sure to get the right backspacing. with stock, you will need spacers. hope that helps!
Old Jul 2, 2008 | 08:57 AM
Lanster's Avatar
I have the same set-up as axsys I cut some of the cheap plastic skid plate off. No rub. The body lift should take care of any issues for you.
