2" Bodylift And ESP
With a 2" BL, with some manufacturers, you have to remove the steering joint to install a relocation bracket. And when you put back the shaft, it's possible that the position will not be exactly the same. THAT's why you have to recenter the steering sometime
To w squarred: don't judge too fast
Be aware that a 2 inch body lift will raise the center of gravity of your vehicle. Not by a lot, but it does raise it. That means that you're a little bit more top-heavy, and you may see a bit more body roll while going around corners at speed. Take a bit of time to get used to the way your Jeep handles after being lifted.
