2" budget boost?
Old Jan 20, 2008 | 04:22 PM
tahoe_jk's Avatar
Default 2" budget boost?
I just put new 275/70/R18 Wrangler Silent Armors on my '07 Sahara Unlimited 4dr. Great all around tires for the weather / wheeling environment here in Tahoe. I'm surprised that several other folks running 33" rubber aren't having any rubbing issues - mine rub quite a bit at full turn and I'm assuming will rub even more with articulation. What are people running for 2" budget boosts? I saw the Teraflex install in the FAQ section, but am curious what else people are happy with.
Old Jan 20, 2008 | 04:27 PM
IndianaJK's Avatar
Did you put the tires on your stock wheels? You need wheel spacers to correct the rubbing. A lift will only help when off road under heavy articulation.
Old Jan 22, 2008 | 12:42 PM
tahoe_jk's Avatar
Yes, the tires are on the stock 18" rims. Based on other posts, it looks like I need 1.5" spacers. Thanks.
Old Jan 23, 2008 | 11:57 AM
tahoe_jk's Avatar
For what it's worth...
After reading the boards and consulting with my local jeep mechanic, I decided to install the Teraflex 2.5" budget boost + new shocks to correct the rub (at full turn) with my 275/70/R18 Wrangler Silent Armors. The mechanic confirmed what many others on the board say - that the boost + shock extenders work OK for onroad, but he said you'll be disappointed if you use the extenders and do anything beyond driving down a dirt road. The kit has fixed the rub and the ride is great. Haven't had a chance to take it offroad yet.
Old Jan 23, 2008 | 12:06 PM
BaltChief's Avatar
And it looks better too...right!!
Just an fyi....check your drivers side rear wheel for clearance on the sway bars...mine was awful close with a little rubbing offroad. You can either use spacers, get new wheel with more BS or adjustable track bar or relocation bracket like the BDS if this is a problem on yours. Mine was a 2dr and a 2008, that may make a difference.
Old Jan 23, 2008 | 05:29 PM
tahoe_jk's Avatar
Ha, yes, looks much better! I'll keep an eye on the rear wheel rub. I haven't been offroad since installing the lift. I did notice some other folks mentioning that with the Teraflex bb, tho. Thanks for the info.
