2 door auto lift ?
Old Oct 25, 2010 | 04:06 PM
jeepsta's Avatar
Default 2 door auto lift ?
I have a 2 door auto want to install a spacer lift 2.5 i will not have to worry about the drive shafts or anything else i was planning on the teraflex one with the shocks. I just drive it back and fourth to work and a little mudding nothing serious. Also any pics of this setup with a 1.25 body lift as well thanks for the help..
Old Oct 25, 2010 | 04:57 PM
MoabBrink801's Avatar
X2 agreed you could get away with 3.5 if you don't plan to flex hard. My dads rubi automatic with the 2.5 budget boost tore with 1200 miles but it was flexed to the max My brother has 4500 miles with a 3.5 lift and an auto no probs but it hasn't been flexed hard . The trans pan rips the boot at full flex when the passenger front tire gets stuffed into the fender all the way
Old Oct 26, 2010 | 04:10 PM
jeepsta's Avatar
I just want to use spacers so i can get a true 2.5 lift some say the coil lifts give you more if you dont have the extra weight.
Old Oct 26, 2010 | 04:14 PM
If you have bumpers and winch expect about 1 1/2 " in the front and about 1" in the rear I had the 2.5 bb and it worked great till the extra weight came into play
