2 Inch Lift - Noise over bumps
Old Sep 26, 2007 | 01:15 PM
maliki's Avatar
Default 2 Inch Lift - Noise over bumps
I've got the 2 inch FT lift, M-Force shocks, and the front FT Adjustable track bar - all else is stock. Overall - lift is perfect for my needs and it actually drives (much) better than stock.
BUT after a couple weeks, I have a deep 'squeak' coming from (I believe) the front when going over bumps... Drives fine, and I've been underneath and everything looks good - no noise when phsyically pushing down on the suspension.
Anyone else experience this? Could it be the bushing or spherical joint on the adjustable track bar? Thanks!
Old Sep 26, 2007 | 01:20 PM
bodybrdng's Avatar
Might need to grease the shock bars
Old Sep 26, 2007 | 01:45 PM
crossbones's Avatar
I've read other posts about the FT track bar squeaking do a search and you will find it as well as the remedy for it. Good Luck I am sure it is annoying as hell.
Old Sep 26, 2007 | 02:08 PM
pulman01's Avatar
Its the bushing/sleeve. You have to take it off and grease it. I have the same issue. I thought I read where someone put a zerk fitting on theirs so they wouldn't have to drop that side just to grease it. I would imagine that you would have to drill all the way down through the sleeve to do it.
Old Sep 26, 2007 | 08:34 PM
maliki's Avatar
Should have done a better search before posting - looks like it's already covered on this post:
https://www.jk-forum.com/forums/show...ghlight=squeak
White Lithium Grease every few thousand miles - sounds easy enough.
Thanks!
Old Sep 26, 2007 | 10:01 PM
wayoflife's Avatar
JK-Forum Founder
Thanks!
Actually, if you install it right and apply white lithium grease upon assembly of the bushings (see step #2 on my writeup below), you shouldn't have any squeaking for a very long time. I have over 11,000 miles on my track bars and they still don't squeak.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Sep 27, 2007 | 04:57 AM
BLKRuby's Avatar
Actually WOL, i had greased on install inside and out, and alos took the bushingout 2 different times to re grease and the noise kept coming back.
So i added the grease zerk to the TB back in July and have not had a aqueak again. I am very happy with my mod and would do it again and recommend it to anyone.
Old Sep 27, 2007 | 06:06 AM
wayoflife's Avatar
JK-Forum Founder
Yeah, I've seen your nice write-up and I'm glad that it fixed your problem but in all honesty, I have yet to have a problem with mine in all the miles that I've put on mine nor has Rubimon, Puddlz, CLACKEY(_!_) any of the other guys I know who run this setup and installed their track bar this way. Granted, when it does come time to re-grease my track bar (because everything eventually needs greasing), I will definitely do what you did
