JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   2 in mopar lift (https://www.jk-forum.com/forums/modified-jk-tech-2/2-mopar-lift-273098/)
RUSSB442 Apr 26, 2013 01:13 PM
2 in mopar lift
can your run 35 km2 on stock rims with the 2in mopar lift. Mopar claims to accomindate
35 in with the 2in
ORWJK Apr 26, 2013 01:25 PM
yes you can but you'll need to get some 1.5" wheel spacers to correct the backspacing issue's with the factory wheels with 35s. I would personally recommend just going with a Teraflex 2.5" budget boost, tons of people here on the forum run that and absolutely love it!:thumbsup:
Tripletsi Apr 26, 2013 01:47 PM
2 Attachment(s)
I completely agree with ^ORW on the TF 2.5" BB over the Mopar 2" kit. My brother paid $2500 for the 2" Mopar kit installed compared to my $300 for the TF 2.5" BB and my Jeep is taller than his! Yes he has Fox shocks and some more gadgets but its not worth it for only 2". It even ended up sagging after installing his bumpers and we needed to put 1" pucks on top of the coils to clear his 33's. IMO 2.5" is perfect for 33's, if you're going 35" tires then you should look at a 3/3.5" lift kit. My brother regrets his at least...
Mine is the black Jeep his is the red Jeep, both have 33" tires:
Attachment 451435
Attachment 451436
kh202 Apr 26, 2013 02:47 PM
2 Attachment(s)
Attachment 451450
Attachment 451451
Love my teraflex 2.5" bb and 35" km2s. I'd recommend cutting fenders with either one. For $300 you can't beat it
Kaptain17 Apr 26, 2013 05:11 PM
Originally Posted by kh202 (Post 3533562)
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=451450"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=451451"/>
Did you also get the teraflex adjustable trackbar? I had my lift put in yesterday and they are recommending that I get that for the jeep.
kjeeper10 Apr 27, 2013 12:15 AM
At 2.5" or less the shift in the axle is going to be minimal. 3/8's or even less.
I would keep your stock unless you have issues.
kh202 Apr 27, 2013 04:55 AM
No I just installed the rear bracket that came with
JK-Ford Apr 27, 2013 06:53 AM
35 in with the 2in
Pretty sure you can run 35's and no lift ( with flat fenders ).
Dbmoorejr Apr 27, 2013 08:36 AM
You can run them with no lift. You need wheels!! Stock is too thin and you will get about 70 of tread life. A lot if wear in the center
RUSSB442 May 1, 2013 08:50 AM
i love the look of the stock 10th anniversay rim. i wish someone would make a wider and correct backspacing to run on my jeep
© 2026 MH Sub I, LLC dba Internet Brands
