2 Questions About Rake!
1- Just installed a Smitty front bumper and Xrc 8 winch on my 2010 Sahara 2 Door, it has a Teraflex 2.5inch suspension system (with the 9550 socks). To me, it seems like the bumper+winch has sagged the front end down, even though I am not 100% sure? How can I measure? Like where would I want to measure to see how much lower the front end sits than the back? Frame? Bumper? Roof?
2- If I was going to add a lift to level it, would a set of .75 inch spacers in the front be too little to make it level? Too much? Just right
Thanks a ton!
? Thanks a ton!
what you can do as well is get a couple spacers since they are dirt cheap and see what fits your preference.
maybe a 1/2" to 3/4" in the front and if necessary to level it out again, another 1/2" in the rear.
Depends on your taste, some out there like a little bit of rake
When the center sections of the frame rails (under the doors) are level:
The bottom of the front end of the frame rail sits 75.8mm (2.98") higher than the bottom of the rear end of the frame rail.
