2?s one quick discos and second spare mount
Old Feb 24, 2011 | 10:53 AM
BigBallin's Avatar
Default 2?s one quick discos and second spare mount
1st question.
i have been reading and seems like a lot of people like jks quick discos, i was looking at the tera flex because they have the mount to pull the sway bar up and away. and no need to hassle with bungies. could the mounts that teraflex sells be used with the jks? or is teraflex just as good and just go ahead and run that? or are there any other setups to consider ?
2nd.
how are you guys mounting your spare 35inch tire and rim on the back?
was thinking about using this www.quadratec.com/products/22202_2000.htm
but some one has said that there as been issues of the tire pulling and bending the door.
Old Feb 24, 2011 | 10:58 AM
BLK08JK's Avatar
So where's the question in part 1?
Old Feb 24, 2011 | 10:59 AM
BigBallin's Avatar
ha sorry. must have deleted it
Old Feb 24, 2011 | 11:05 AM
BLK08JK's Avatar
I'm just paying attention to this because I have the same question... I like the sound of the teraflex mount thing. the only other way I know for quick discos is the DIY route by drilling a hole through the bolt and using a pin instead of a nut to keep it in place.
Something like this: https://www.jk-forum.com/forums/show...IY+disconnects
Old Feb 24, 2011 | 12:05 PM
burbingus's Avatar
I like the JKS disconnects becuase they're adjustable. You can always use a zip tie or dual d ring strap to tie the swaybar to the frame. I went to strapworks dot com and ordered some straps.
As far as using a 35 on the stock tire mount - I would not do it. Over time it will wear on the hinges and make the tailgate sag.
