I'm debating on a snorkel hood scoop or a cowl induction scoop for mine. Which do yall think will give me the most horsepower? I'm leaning towards the snorkel. Will 454 stickers help? :rock::harhar:
Originally Posted by pearl-drum-man
(Post 1320787)
Who told you this in the first place?
Yeah, I know about it from a technical point of view. It won't work. It might bolt up, I don't know. But, it won't add any power whatsoever, because you have to have something else in the mix besides more air. More fuel. What's gonna tell the PCM to inject more fuel? Nothing. All you'll end up doing is leaning your engine out and damaging it. Happy trails.
Originally Posted by RedneckJeep
(Post 1320800)
But without changing the intake runners I don't see how you would get more air in. All that being said I don't think it would work either, but as stated earlier in the post if all 10 cylinders are attached then it might give a boost in power. |
Besides the electrical BS with our jk engines, why wouldn't it add more power like it did with my bored out throttle body on my old cherokee? Defintely noticed a difference there. Not saying the viper one bolts up or not (highly doubt it anyway) but would be cool to find something that would work.
Get a baseline dyno pull.
Bolt on Viper TB. Run dyno again. Report. Now we all know!!:ya: |
Originally Posted by goldtr8
(Post 1320808)
O2 sensor should tell you to add more fuel, also there should be some sensor either MAP or hot wire measuring air.
This certainly isn't as preposterous as it may sound. I know there are various years of the V10 that use dual throttle bodies, so they aren't all that far off in terms of airflow. As for fuel, I'm certain there is a little overhead available with the current fuel pump and injectors, but not a lot.
That said, even if it does bolt on and the PCM properly communicates with it, you still need a throttle body relearn so it makes the appropriate calls. When someone has a programmer that has a throttle body relearn feature then it might be time to investigate, but today that seems a long way away. |
Originally Posted by JPop
(Post 1320919)
(Post 1320564)
Unless you get a throttle body relearn tool/programmer that can adjust the PCM, it's all for not.
Signed, The Word Police |
