2010 Superchips issues???? HELP
Old May 28, 2010 | 04:56 PM
hardjeep78's Avatar
Default 2010 Superchips issues???? HELP
So I picked up my brand new 2010 JK Unlimited two weeks ago and dropped it off immediately for a 4" lift, 35" tires, bumpers, exhaust, intake and a Superchips programmer for a little more pep.
Unfortunately, once programmed, the TPS light came on (even though our download included the delete function for the TPS). ANNDDDD to make it worse, once we changed the tire size to 35", the speedo wouldn't work and the check engine light came on.
After 20 minutes on with Superchips they said that the issues i'm having are common with the 2010 jeeps.....anyone else having this issue? Does anyone have a solution? Is there another programmer out there that works better without the issues i'm having?
thanks for your help guys (and gals)....
Dave
Old May 28, 2010 | 05:25 PM
superman_jjs's Avatar
I just purchased mine today. I dont have mine lifted yet but I did get a code and I called them. They walked me through a couple of things and it works fine now.
Old May 28, 2010 | 05:34 PM
hardjeep78's Avatar
Yeah when we first uploaded the "tune" everything was fine. I drove it for three days and no problems....but then I went back to download the TPS information and thats when i got the tires/wheels put on and once we tried to change that tire size that's when we had the issue....prior to that we didn't have any issues.....let me know what happens when you try to change the tire size.....
Old May 29, 2010 | 06:54 AM
Coley's Avatar
I updated my tuner with the TPMS disable option and it seems to have worked fine on my 2010. Haven't changed the tire size yet though.
Old May 31, 2010 | 01:32 PM
Coley's Avatar
Turns out I did have an issue with the TPMS Disable setting on mine. After updating the tuner again, it worked fine today... no more Tire Pressure light for me.
Old May 31, 2010 | 02:16 PM
wildandwillin's Avatar
Yes it takes a few times to download, glad it all worked out for you
