2012 camber adjustment.
Old Oct 21, 2012 | 07:08 AM
bombout800's Avatar
Default 2012 camber adjustment.
I went two days ago for an alignment. There isn't a factory caster/camber adjustment from what I was told. Im lifted 4" and the caster on each side is off exactly 4.7 on each side. An ideas on fixing this? Adjustable ball joints? Camber bolts? Anyone have any experience they can share. Any input will be greatly appreciated!
Old Oct 21, 2012 | 07:31 AM
Delux2769's Avatar
Stay away from Cam Bolts.
Get yourself some adjustable Front Upper control arms to fix your castor issue.
Adjustable balljoints are nice for smaller castor issues( from what I've been told).
Old Oct 21, 2012 | 07:35 AM
Ncb's Avatar
Ncb
Caster should be good at 4.7 and is adjusted by adjustable control arms.
Camber is fixed in stock trim, but can be adjusted by adjustable ball joints. I wouldn't worry too much about the camber.
Old Oct 21, 2012 | 07:36 AM
bombout800's Avatar
Well my lifts control arms should be adjustable correct? I may be wrong
Old Oct 21, 2012 | 07:39 AM
Ncb's Avatar
Ncb
That all depends on the lift. What exact caster setting are you wanting?
Old Oct 21, 2012 | 07:47 AM
bombout800's Avatar
I don't know much about it. I really want everything in line and correct. I was told if I keep the tires rotated regularly I should be fine. But I don't know how bad it is by just the numbers
Old Oct 21, 2012 | 08:43 AM
Robar's Avatar
Read this ----> Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Even if you're not going to do this yourself, it has some good info.
Old Oct 21, 2012 | 09:03 AM
drumnatural's Avatar
U need lower adjustable control arms to adjust camber/caster. Upper control arms are for pinion angle.
Old Oct 21, 2012 | 09:05 AM
Delux2769's Avatar
Yes, I get those two sets confused all the time.
Old Oct 21, 2012 | 09:16 AM
bombout800's Avatar
Sweet! What I need to figure out is if my 4" rough country lift has adjustable lower control arms.
