2012 exhaust spacers needed?
Old Nov 16, 2012 | 04:50 AM
1978cj7jk2012's Avatar
Default 2012 exhaust spacers needed?
Already have a rubi spring swap thet netted just under 2 inches. I am about to add a 2.5 budget boost on top of that. Are the spacers needed? At only $40 they arnt a problem, I just don't want them if I don't need them.
Old Nov 16, 2012 | 04:58 AM
JKbender's Avatar
I know it is more money but I would sugest getting a new 1310 front drive shaft instead, you will end up needing it in the long run anyways. But yes you will need to do one or the other.
Old Nov 16, 2012 | 05:25 AM
rb1boxer_3's Avatar
Spacers are not needed. I have a 3.5" rk lift and its fine. For now but the ds will be much better and safer
Old Nov 16, 2012 | 06:30 AM
12HTownSahara's Avatar
I've heard the spacers tend to fall out or loosen up. I took mine to an exhaust shop and just had them cut and redo that section of pipe.
Old Nov 16, 2012 | 07:20 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
You have never flex then, spacers or a driveshaft is absolutely needed on the 2012 with any kind of lift
the spacers will not just loosen up or fall out.
I would suggest replacing the front driveshaft with an after market 1310. If you do any kind of wheeling you will eventually destroy the factory shaft.
Old Nov 16, 2012 | 09:32 AM
awinski's Avatar
the spacers gave me like an inch. it was enough for my 3.5 at full droop, but if i did it again, id just weld in a section of pipe. id go with the drive shaft, youll need it eventually. unless you don't have the money now thatd be the only reason why i wouldn't go DS
Old Nov 17, 2012 | 05:24 PM
I have the money but a new driveshaft isn't an option due to my warranty. I don't wheel this jeep too hard, it's my daily driver and I'm building a cj7 on Dana 60s, 500hp motor, and 44s, so with that being said, will my jk be ok when daily driving and mild wheeling? Are the exhaust spacers needed?
Old Nov 17, 2012 | 07:28 PM
josho66's Avatar
A new drive shaft will void the warranty, why is that?
Old Nov 18, 2012 | 07:00 AM
JKbender's Avatar
If the dealer wants to void your warranty, the lift already gives them the reason to. The drive shaft will not realy change the warranty position.
Old Nov 18, 2012 | 05:19 PM
I have already gotten the ok to do the lift as long as I don't mess with the axles or shafts
