2012 Full Traction question
Hey Folks, New to the JK scene almost... (I ordered a 2012 Rubi unlimited last tue and won't see it till Dec.) but not new to Jeeps. I want to run the Full traction 6 inch Long arm lift, will I need new drive shafts? Just read something about the rubber boots burning off the stock drive shaft and causing problems at full suspension droop due to the exhaust??? Any input would be appreciated. I'll post pics as soon as I Recieve the jeep..
Yes, with a 6 inch lift you will need new drive shafts.
Originally Posted by 2012JKFNG702
(Post 2590253)
Why do you want to go with a 6" lift? You don't need that much lift for a JK. There are many people on this forum running 40" tires with less lift than that. I can run 37" tires with my 3.5" lift. With some minor body/fender mods, I could run an even larger tire. Aren't you concerned about having a high center of gravity that will increase your rollover chances? |
| All times are GMT -8. The time now is 02:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
