2012 jk four door rim size
Old Oct 17, 2013 | 02:10 AM
Gieringer11's Avatar
Default 2012 jk four door rim size
On my 2012 JK four-door Rubicon can I run a 15 inch rim what should the offset be?? Is more rubber better than less rubber? I was thinking of 35 12.5. 15. way cheaper
Old Nov 25, 2013 | 05:55 PM
Albertsiebenhor's Avatar
I run a 15x8 -19bs mb chaos 5 with 37"
Old Nov 25, 2013 | 06:09 PM
stagedtrip's Avatar
Backspacing of at least -4.5 (I run -3.75)
You will have to grind a little off the front caliper housings to fit most 15s
