2012 jk hub assembly
Old Jun 18, 2021 | 07:17 PM
jdhunter87's Avatar
Default 2012 jk hub assembly
Hi all new here and first post.
I am in the process of replacing my drivers side front hub assembly. I was able to remove 2 of the 3 Hub bolts but the 3rd snapped... My question is there only threads in the hub or are there threads is the knuckle. Will I have to drill that bolt out?
thanks,
jeff
Old Jun 18, 2021 | 07:36 PM
resharp001's Avatar
Loved
Community Favorite
Only threads in the unit bearing itself, nothing in the knuckle.
Old Jun 22, 2021 | 05:06 AM
BLK HOLE's Avatar
If you were that far you should have been able to pull the hub off. Just throw it away and buy new bolts.
Old Jun 22, 2021 | 09:30 AM
Scott2012's Avatar
+1 on buying new bolts! Also, I would suggest a more "premium" 12 point socket for these... I have found that my cheaper sockets are more likely to mess up the head of these bolts; so I bought a Snap-On version and it did a great job when I torqued these bolts to spec. Also, make sure to use some thread locker blue on these bad boys.
Old Jun 28, 2021 | 10:05 AM
jdhunter87's Avatar
HI all thanks, I was able to get it off with a lot of persuasion and ordered new bolts.
