2012 JKR TPI question
Old Mar 1, 2012 | 12:55 PM
1-2 crush's Avatar
Default 2012 JKR TPI question
Going to be putting some 35s on a set of stock 17s that I'm getting from a friend. Planning on keeping my stock tires for winter and back up set. The question I have is the set he has came off a 2007 and have no TPI. Can I just mount them up and run them without them with a pro cal? Or would i be better off buying a new set of TPI and if so any good ideas where to pick some up for a reasonable price?
Old Mar 1, 2012 | 01:08 PM
Rule18's Avatar
If you run without the sensors, the light will always be on. I'm pretty sure the sensors run new about $100 each and I'm NOT sure if you can get them aftermarket or just from a stealership. Personally, if the light doesn't bother you than there's your answer. Cheers!
Old Mar 1, 2012 | 01:14 PM
snowdog's Avatar
I used my pro-cal to set the pressure threshold to 0 psi when I put my aftermarket wheels on. No light. As long as my tire pressure doesn't go below 0, I'm good!
Old Mar 1, 2012 | 01:45 PM
Rule18's Avatar
Nice one...
Old Mar 1, 2012 | 01:50 PM
Fodder4U's Avatar
Unfortunately that is not an option for the 2012's yet
Old Mar 1, 2012 | 02:38 PM
1978cj7jk2012's Avatar
I'm running my aftermarket wheels without one. The light is on all the time but after the first week you will forget about it. And if your like most guys on here you don't need a number on a screen to tell you our tires low.
Old Mar 1, 2012 | 03:09 PM
Redman333's Avatar
If your running 35s you'll have to set the tire pressure lower than the factory threshold anyway so the light will be on even with the TPIs so just run without them. At least until the have a programmer for the 2012s. Assuming whoever said that's not an option for the 2012s is right. I don't personally know wince I don't have my 2012 yet so haven't even looked at programmers yet for it.
Old Mar 1, 2012 | 03:35 PM
hasten3's Avatar
Yes it is...I am using a Pro-Cal for for that on my 2012
Old Mar 1, 2012 | 03:51 PM
Redman333's Avatar
Well there you go, disregard my comment then lol.
Old Mar 1, 2012 | 04:00 PM
DanieltheManual's Avatar
Confirmed, they are 2012 compatible....there's a sticker on the box..
