2012 Passenger side front shock removal??
Old Jul 25, 2012 | 09:10 AM
4x4chick's Avatar
Default 2012 Passenger side front shock removal??
Hi everybody.
We are planing to put a lift on our 2012 Rubicon. Everything looks doable but I just have one question. How do you remove the top nut of the front passenger side shock?? I can just get my hand in there but there is no way I can get any sockets of any kind in there.
Any help will be appreciated.
Thanks
Old Jul 25, 2012 | 09:33 AM
jm102602's Avatar
I used an offset box wrench to get mine off, I have a 2011 but I'm pretty sure its the same thing.
Old Jul 25, 2012 | 10:20 AM
scemracing's Avatar
I took a dremel and trimmed a little plastic from in front of the nut you can't even tell I did it but it made the job a lot easier!
Old Jul 25, 2012 | 10:54 AM
renegade4x4's Avatar
This is what worked for me!
Old Jul 25, 2012 | 11:02 AM
4x4chick's Avatar
Thanks, I will have to look into all of this. It is just so tight in there that I can just get my hand in there. Don't know how I will get leverage to un-do the nut and re-install the new one.
A friend told me that someone told him the take the battery and fuse box out. I don't mind taking the battery out but don't want to mess with the fuse box.
Old Jul 25, 2012 | 12:36 PM
NCRUBI2012's Avatar
Default Cut the plastic
Trust me and other before me on here, cutting a small "window" in the plastic is the only way to gain access. The plastic is thin so you can use a utility knife to scribe and then pliers to pull away where you cut. Takes a few minutes and will make your install easier. No one will ever know you did it if it is cut square.
Old Jul 25, 2012 | 12:45 PM
Pjohn's Avatar
I took mine out with an open end wrench but had to cut the plastic above to install the new shock.
Old Jul 25, 2012 | 12:46 PM
CRUSH2012's Avatar
Cutting a small tab out with a dremmel is the best way it is about 5/8" high and 1 1/4" long. I used one of those ratchting box end wrench that has a swivel built in ala Harbor freight co. worked very well. Don't even try the battery box gig it's alotta work.
Old Jul 25, 2012 | 01:00 PM
4x4chick's Avatar
Thanks for all the advice. Just spend a few minutes under the jeep to see what the deal is and yes, cutting the plastic will be the way to go.
Old Jul 25, 2012 | 02:40 PM
rkrasko's Avatar
I use a box wrench to get it off and back on. Slowly though. Cutting would make it easier
