2012 regear owners.
Old Feb 12, 2012 | 03:24 AM
kgw350's Avatar
Default 2012 regear owners.
I have a 2012 4 door rubicon auto im running 37s now on the 4:10s.
So my question how are the 5:13s with the new drivetrain? If am in the process of buying a pop-up camper and i tow a boat. I drive from florida to ny once a year. My 37s have about 1 year then im going 40s unless a smoking deal comes along on 40s might be sooner.
Anyone with a 2012 auto please comment on your gears 4:56 , 4:88 , 5:13 and tire size.
Old Feb 12, 2012 | 04:22 AM
hasten3's Avatar
I own a 2012 Rubicon Unlimited automatic and just installed 4.56 gears and running 35" tires, I personally think that is the best set up for 35" tires. I am running 2700 rpm at 70mph and getting 16.8mpg. There is a chart on this forum that jpop did for the 2012, if remember correctly for an auto 4.88 for 37's and 5.13's for 40, but I would find the chart to make sure.
Old Feb 12, 2012 | 04:33 AM
jgerhard's Avatar
Newbie question alert. Got Nitto Trail Grapplers in 285/70/r17. THe gear chart in the FAQ shows I need to re-gear, possibly to 4.56. What is the cost of the labor for this, and do you need to go to 4wd specialist or can you just go into a good shop and have this done?
Old Feb 12, 2012 | 04:36 AM
JPop's Avatar
Here's a link to the chart in the FAQ. Just scroll down a bit for the Pentastar chart.
https://www.jk-forum.com/forums/showthread.php?18617-MODIFIED-TECH-FAQ-Answers-to-the-Questions-Every-Newbie-Has=&p=211276#post211276
With your situation and agenda 5.13s are probably the best path. More than enough gear for the rigors of 37s and towing while keeping you at a good range for when you upsize your tires to 40s.
Also, here's the chart.
Old Feb 12, 2012 | 06:45 AM
kgw350's Avatar
Thanks for the info and chart jpop.
Old Feb 15, 2012 | 09:15 AM
MurderedOutRubicon's Avatar
Thanks for finding the chart ive been looking everywhere for this
Old Feb 15, 2012 | 10:01 AM
JPop's Avatar
The chart is based on actual tire size, not the advertised size.
Old Feb 15, 2012 | 10:04 AM
JPop's Avatar
Originally Posted by Mr Rubi
based on your RPM range of 2700 @ 70 mph, the charts indicates that you are running 4.88 gear ratio but you have clearly stated you just installed a new set of 4.56 gear ratio. What gives?
The actual tire size is the difference. The 35" tires mentioned are probably running closer to 33s. That makes up the difference in the discrepancy noted.
Old Feb 15, 2012 | 10:12 AM
TeraFlex's Avatar
Sponsoring Manufacturer
I'm running 37's with 5:38's in my 2012 Rubicon Unlimited. Digs awesome in the sand and takes off fast at the stop light. However it's not best on mpg's , avg is 14.74 right now . I was thinking about swapping to 5:13's for a little better mileage or even 4:88's but it's hard to get away from the power that I have now.
Old Feb 15, 2012 | 10:19 AM
lensstj's Avatar
Interesting looks like I just need bigger tires to be in the green! LOL I was looking for this chart and figured so based off how this jeep drives but now I see it on paper. Moving onto 35's for my 2012.
