2013 jk 2dr- Need Help
Old Feb 20, 2014 | 06:37 PM
AZNICKJAMES's Avatar
Default 2013 jk 2dr- Need Help
I recently bought a 2.5 in TeraFlex lift W/Shocks I am adding quick disconnects to the front sway bar. Now Is the going cause any issues with the stock brake lines when I'm wheeling? Second I am going to run 35s with 18in rim Ive been told I wont need spacers but I have also been told I will? I bought 1.5in spacers just in case. All is being installed on Tuesday (waiting for superchip to arrive) Any advice/guidance would be a big help! Thanks
Old Feb 20, 2014 | 07:18 PM
rocklikethat's Avatar
the need of spacers will depend on your wheels back spacing, it should 4.5 inches or less. As far as the other stuff, Idk, my 2.5 won't go on for a few more weeks.
Old Feb 20, 2014 | 08:00 PM
AlexjeepVb's Avatar
If the rims are stock you will need spacer, if aftermarket with about 4.5 backspace or less you will be fine. As for the brake lines, you will need to remove the front brake line and bracket thats attached to it, and then zip tie your brake line to your shock and you will have plenty of room to flex(This is actually what instructions say to do so don't worry works great) as for the rear if the kit didn't come with a brake line bracket extender, you can make one pretty easy.
