2013 unlimited
Old Oct 1, 2012 | 06:17 AM
notsoricer's Avatar
Alright guys, feeding time is over for this fella. Time for him to crawl back under his bridge until next time...
Old Oct 1, 2012 | 01:38 PM
deving's Avatar
I Already put new driveshafts and 5.13 gears. i had a 4 inch suspension on it. i was runnin 35x12.50 mud grapplers.
Old Oct 1, 2012 | 02:33 PM
Falcon03's Avatar
Default Hemi as part of the line up
When is jeep going to add the Hemi engine as an option...
Old Oct 1, 2012 | 02:54 PM
BigSteve's Avatar
tomorrow
Old Oct 1, 2012 | 03:21 PM
BKGM Jeepers's Avatar
Originally Posted by deving
I just put a 6 inch long arm lift on my 2013 unlimited. I also put a 1 inch body lift on it. Will i be able to run 40 inch tires??
4" were getting you 35's, while 7" will get you 40s?
Assuming this is a real post, there is a lot more going in to 40s than just your lift. 40's won't clear your rear wheelwells. The tires are way too heavy for the factory lockers, even if you have a rubicon. The front tires will tear up your sheetmetal as you compress your suspension while turning.
I run about 6.5" of lift to clear my 38-14.50's. They still rub on the front under compression and I use nitro bumpstops to limit my uptravel (to my steel tube fenders). My rears stuff perfectly, but 40's won't fit like my 38's so you'll need to limit uptravel back there too.
I run dual 60's, the Rubicon T-case (my jeep was originally a Rubicon), and now hydro assist becuase the aftermarket track bar mount ripped off my frame from the stress of the tires. I updgraded while rebuilding my mounts. I forgot to mention that you will destroy your e-swaybar with the weight of the axles/tires/wheels/lift/etc so if you have one, I'd get manual disconnects to protect it when you're off road.
Assuming you're just going to drive around town on 40's, you're probably ok. If you wheel it, you're just starting off on a big build - either proactively through patience or manually as you break stuff wheeling.
Old Oct 1, 2012 | 03:32 PM
bigT's Avatar
I just bought a grave digger monster truck and mounted my jk body on it. What alcohol mileage should I expect? TROLL ALL THE WAY!!
Old Oct 2, 2012 | 08:09 PM
notsoricer's Avatar
so on your 2013, you've already been through 2 lifts? and you "were" running 35's? so what you're saying is that you already got the 40's mounted? did you get the new tuner that yields 100hp increase and +20mpg over stock? heard its the bees-knees
Old Nov 7, 2012 | 06:36 AM
deving's Avatar
Theres pics... almost done..
ID:	386194   Click image for larger version
ID:	386195   Click image for larger version
