2014 Rubicon or Sport?
Old Oct 14, 2013 | 02:05 AM
BigRed0625's Avatar
Default 2014 Rubicon or Sport?
Ok so it's time for me to make my final order on my new wrangler.....
I'm planning on pulling the suspension and axles out of the stock jeep to replace with the Evo Double Throwdown lift and the DynaTrac Pro rock 60's(5.13 and ARB air lockers)....
Is there any reason I should fork out the money for a Rubicon if I'm getting rid of everything that makes a Rubicon a Rubicon?
As I understand, in the JK's the suspension, Axles, and Transfer case is the only things that separate the rubicon from the other trims?
Should I just get the Sport and use the money I'd save to get a Atlas II T-case?
Old Oct 14, 2013 | 02:35 AM
nthinuf's Avatar
No
And the lazy-mans e-disco.
Yes
Old Oct 14, 2013 | 02:38 AM
BigRed0625's Avatar
Sweet....that's what I currently have on my order paperwork....4 door Sport it is.....lol
Thanks!
Old Oct 14, 2013 | 02:43 AM
Gman*2007's Avatar
X2 the Sport would be the way to go.
Old Oct 14, 2013 | 03:04 AM
kh202's Avatar
Yup, what they said! At that point, you'd be paying $10,000+ just for a sticker that says "Rubicon". You may want to re-examine your need for 5.13 gears with the Pentastar, although you didn't say what tire size you were planning, depending on what your plans are with the rig. 5.13 can be overkill if you do a lot of highway.
Old Oct 14, 2013 | 03:16 AM
BigRed0625's Avatar
My plan is to run 40x13.5 Wrangler MT/R's.......
Old Oct 14, 2013 | 04:08 AM
kh202's Avatar
Well that's a fun plan Should be perfect.
Old Oct 14, 2013 | 05:51 AM
Jersey_Devil's Avatar
Sport and atlas transfer case!
Sent from my obama monitoring device
Old Oct 14, 2013 | 08:04 AM
BigSteve's Avatar
If you plan on swapping out the suspension and the axles, why even bother with buying a new JK? Why not find a nice low mileage used vehicle and save a little extra money? Once you swap out the parts your not going to have much left to warranty anyways. With the money you save then swap in an atlas.
Old Oct 14, 2013 | 08:14 AM
kh202's Avatar
By the sounds of his build budget, I'd say, because he can
