2014 tpm on older jeep
Old Aug 28, 2014 | 05:49 PM
rino7603's Avatar
Default 2014 tpm on older jeep
I just bought 18" wheels from a 2014 Sahara and put them on my stock 2011 sport. I am assuming the tpm sensors from the new Sahara are not going to be read by the computer? I have read about older wheels on the 2013 and newer vehicles not working, is it the same my way too? I don't want to take the sensors out of my old wheels because I will be putting them back on in the winter.
Old Aug 28, 2014 | 05:53 PM
Vt.rider's Avatar
Your TPMS won't recognize the sensors that came off the 2014. It just doesn't work. Sorry.
Old Aug 28, 2014 | 05:57 PM
Rbzak's Avatar
You are correct. 14 senor will not work on a 11. Bc they are sending a different frequency. I think it was 2012 when they changed the frequency of the senor. Someone else might correct me if I'm wrong.
Old Aug 28, 2014 | 06:18 PM
rino7603's Avatar
So my only option is ignore, disable, or buy older sensors to put in the '14 wheels. Hmmm...which option is the best?
Old Aug 28, 2014 | 06:39 PM
wfd153's Avatar
Another option is to switch the sensors from your old wheels to the new ones. I too have a 2011 Wrangler sport which I switch to the 17 inch alloys with new Goodyear Dura track tires. The tire pressure sensors easily unbolt from the stem – any tire shop can do the swap. FYI the 2011 uses sensors that transmit at 315mhz. I believe that the 2013 and newer use 433mhz sensors.
Old Aug 29, 2014 | 05:43 AM
socal_hemihead's Avatar
I have 3 barely used (less than 6 months) TPMS sensors from my 2008 Jeep that I'd sell for cheap. If interested, PM me.
Old Aug 29, 2014 | 05:46 AM
14Sport's Avatar
2013.
You can buy brand new sensors for your 2011.
Old Aug 29, 2014 | 05:52 AM
Rbzak's Avatar
Originally Posted by 14Sport
2013.
I knew they changed just couldn't remember what year. Thanks for the update.
Old Aug 29, 2014 | 06:52 AM
Vladimer's Avatar
If you got to a tire shop, they can change the frequency on the new TPMS sensors. Its a neat little device and runs about $120 to do it up here. Canadian funds.
Old Aug 29, 2014 | 07:01 AM
14Sport's Avatar
