20x10- what backspacing????
Old May 11, 2011 | 04:47 PM
VETTETHRET's Avatar
Default 20x10- what backspacing????
I want them in board as much as possible. Would a 20x10 with a 4.5" backspacing running Nitto 37x13.5's rub?
Old May 11, 2011 | 05:03 PM
blockrockin's Avatar
should be ok.. might rub alittle on the front control arms when you turn sharp.. depends on your setup.. but should work ok.
Old May 11, 2011 | 09:15 PM
VETTETHRET's Avatar
They *should* work. That being said, I run 10" wide wheels with 3.5" backspacing.....or had that until I added spacers, now I have 2" of backspacing
Thanks guys. I figure I can always add a spacer if need be.
