24v cummins in a jk
Old May 16, 2013 | 07:24 PM
1978cj7jk2012's Avatar
Default 24v cummins in a jk
Might have a chance of getting one from a family member at a good price.. Has anyone done this? I'm no professional but I can hold my own on most projects.. I know it will take some help, some research, and a decent chunk of money but what are everyones opinions? I'm all ears.
P.s. The motor is a very sound 24v that already has moderate mods like injectors and programer and things like that..
Old May 16, 2013 | 07:45 PM
MikxHayward's Avatar
Rattletrap
Old May 17, 2013 | 02:10 AM
Ironhead920's Avatar
You need to modify the fire wall just to fit that in there!
Old May 17, 2013 | 02:26 AM
mook8651's Avatar
At the minimum you would need a D60 up front to handle the weight. Might even have to extend the front of the frame that is a really big motor to fit in there. The 4BT is a tight fit so the 6BT would be a real task.
Also have to think about beefing up your entire drive train axels, shafts, new tranny, prob even a trans to handle that torque. Might even to throw at least a D60 or a 1 ton axel in the back to be able to handle that kinda power.
All an all your look at a lot of money. In the end you you basically have a jeep tub on a totally custom chassis. Just my .02
Old May 17, 2013 | 04:31 AM
Hmmm. Well these answers bring me to my next line if thoughts.. I have a cj7 project and I was thinking about putting rock wells under it instead of what I have now.. If I did that I could put those axles under the jk. The axles currently in the cj7 is a Dana 60 front and sterling 10.5 rear out of a 2004 F-350.. (Motor for cj7 is a very built amc 360 bored and camed and all that)
Old May 17, 2013 | 05:31 AM
mook8651's Avatar
Them axels would be great to put under that. That sterling is pretty much bullet proof they use that in heavy duty 1 ton trucks can't go wrong with that setup. Just the fact of dirt that big of a motor in a JK would be your issues
Old May 17, 2013 | 08:45 AM
How did mbrp get theirs to fit?
Old May 17, 2013 | 09:40 AM
D_engel's Avatar
you may need to modify the gas tank and skid to fit the 10.5 in the rear
Old May 17, 2013 | 10:38 AM
AaronJK's Avatar
They chopped a dodge ram frame.and dropped the tub from the Jeep on to it if I remember correctly. They had to make a new firewall as well. The 4bt is a better option for the jk. Jeff Daniels says they build them with 250 hp and about 500 ft lbs of torque. They have a diesel swap page on their site.
Sent using my SuperSmartThinky Phone
Old May 17, 2013 | 10:48 AM
1995nscajeep's Avatar
It would be legit if it can be done but without severe chassis and drivetrain redesign and a Ton of cash
